Oh boy my camber is WAY off!
Old Apr 15, 2005 | 09:20 AM
Q45tech's Avatar
Remember to align as you drive it, your weight in the drivers seat will change ride height [especially drivers side] thus camber! Same with full vs. empty gasoline on the rear.
Things: Caster and Camber need to be within 0.2 degrees side to side with your weight in drivers seat.
Old Apr 15, 2005 | 04:31 PM
bzabodyn's Avatar
I love my Hotchkis Springs, and after an alignment and SPC camber/toe kit in the rear, I was able to get the following specs:
Front
-1.8 deg r/l, 1mm total toe in
Rear
-1.6 deg r/l, 2mm total toe in
I'm dropped around 1in all the way around and I think it's perfect for what I was wanting...
Old Apr 15, 2005 | 10:19 PM
turbomaxima's Avatar
Man with green rock in Vortech
Originally Posted by OvaYahead
Please anyone let me know if theres another kit out there like 350evo, but half the price. cusco and stillen wont' get you back into factory spec and I'm trying to avoid kinetix.
I'll keep you guys updated if I find more info too.
What's your gripe with Kinetix? It is by far the best bang for the buck and does more adjusting than the 350evo kit. There is some noise at first, but it is the urethane bearings getting worn in (lasts about 200-300 driving miles and you only hear it on hard turns at -10MPH).
Full kinetix kit is $700.00 or so I believe. www.kinetixracing.com ?
Old Apr 21, 2005 | 02:44 AM
g35thanh's Avatar
damn, so wtf?cuscos not enough and kinetix makes noise. i dont wanna pay 800 bucks for 350evo arms.
Old Apr 21, 2005 | 02:45 AM
g35thanh's Avatar
shouldn't .5 adjustment be alright for the front if your negative cambers not over 2.0?
Old Apr 21, 2005 | 10:01 AM
OvaYahead's Avatar
if you get the front camber 1.2 or less, it's considered to be in factory specs.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
