BRAKE SQUEAKS, INFINITI won't work on it
Old Apr 10, 2005 | 02:39 AM
dennis_said's Avatar
Hey guys, I have been bothered by rear brake squeaking as of late (usually when going slowing down at low speeds to a stop light)...
I took the car into the Infiniti dealership adn they said they will replace the pads if there are less than 3mm... I was like, "Gotta be, cuz it's so squeaky"... anyways, they did a test and my fronts are at 7mm (recently replaced by infiniti) and the rears are at 5mm...
So I'm out of luck, any idea why I may get squeakiness? I have painted calipers, but it's been neraly half a year since they've been painted.. any run off should be wiped off by now right?
Thanks in advance guys.
Old Apr 10, 2005 | 10:50 AM
V12's Avatar
V12
well there can be a lot of reasons. but if you have a little bit money to spare, i recomand you to get some performance pads.
and another way to fix it is. go to a brakes shop. they have a spare, that you spare on the pads. it will fill up crakes on the pads. that might be antoher reason your brake making sound.
Old Apr 10, 2005 | 11:39 AM
kenchan's Avatar
One dot of wd40 on the rotor will clean it up. don't use any more
Old Apr 10, 2005 | 11:56 AM
Thanks for the great advice! Both method's sound great, I will try the easier alternative first! What does a DOT of WD40 mean?
And V12, I'll most definitely check on the spare, how much do they usually run for?
Thanks
Old Apr 10, 2005 | 12:01 PM
mc2's Avatar
mc2
i think he means put some WD-40 on it, in the amount of one dot.
one tiny squirt i guess.
Old Apr 10, 2005 | 12:34 PM
mike552's Avatar
In my experience with BMW's (notorious for brake squeal), I found that the squealing was coming from the Carriers. For those of you who don't know, the carrier is the track that the pads sit on. Everytime you press the brakes, you're compressing the caliper's piston which in turn, moves the brake pads and presses them against the rotor. Find some high-quality anti-squeal compound and put it on the carrier's tracks. Or it could be what kenchan described, which is possible.
Old Apr 11, 2005 | 12:48 PM
slz's Avatar
slz
I must respectfully disagree with the suggestion to put WD40 on any part of the brake assembly. Even a little bit goes a long way. And it is a LUBRICANT (hope I spelled that right) that will naturally degrade your brake's stopping power if it gets on the face of the rotor
Old Apr 11, 2005 | 02:33 PM
BombRush's Avatar
i second that.. the brake squeak was very annoying i would recommand get new pads which lessens the brake dust... or get stoptech brake system it will not squeak =P
Old Apr 11, 2005 | 10:48 PM
kenchan's Avatar
Your rotors and pads are much more susceptible to gunk and oils from normal use
than a dot of wd40 to clean the surface of the pad that has the contamination.
it's not going to hurt it unless you're spraying them like you were using brake
cleaner spray.
The squeek typically comes from oxidation built up on the pads from the rotors
after rain or carwash. the dot will clean that off, but if you spray the damn thing,
it will eat away at your pads and cause premature wear.
Old Apr 11, 2005 | 10:59 PM
pdjafari's Avatar
My pads have also started the squeak at 11k miles...Im going to try to spray the caliper and back of the brake pads w/ disc brake quiet...and spray some brakleen or brake parts cleaner on the rotors...i think that should work..
Old Apr 11, 2005 | 11:36 PM
kenchan's Avatar
yah, try brake cleaner first and if it doesn't rid the noise, try the wd40 trick.
I don't like using brake cleaner cause you need to remove your wheels before
spraying unless you don't care about the wax it will tear off your wheels and
possibly stain the finish.
Old Apr 12, 2005 | 06:19 PM
Chico's Avatar
I had a similar problem and took it upon myself to challenge the dealership and here is what I found.
The dealer installed brand new pads and rotors on my car and the car was squeaking like an old tank on rusted chains. My neighbors down the street could hear me pulling out of my driveway.
Anyway, what I found out was that the mechanic did no replace the HARDWARE kit required in each brake job you get. Which means the spings and fasteners for the calipers and pads, were not holding the brake assembly together tight enough, thus causing a lot of play and noise.
I took it back to the dealer and agreed with me and re-did the whole thing and got a free oil change for my trouble.
Not sure if this is what you have, but service people tend to dismiss your claims just because their computer says something else.
By the way...DO NOT USE ANY LUBRICANTS on your brakes. Anything, happens and the insurance company and the dealer will not be liable. YOU WILL.
good luck.
mike730
Jan 12, 2018 04:25 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
ddietz97
Jul 26, 2015 06:16 PM
Lsantana757
Jul 20, 2015 09:08 AM
