GT SPEC Brace Package
Old May 4, 2005 | 01:34 PM
JUAN's Avatar
Thumbs up GT SPEC Brace Package
GT Spec Lower Tie Bar/Lateral Brace Package For 350Z
Includes: Front Lower Tie Bar, Rear Lower Tie Bar, And Rearl
I just installed this kit in my G, it was super easy to install (under a hour) and Rear Lower Tie Brace will only fit depending on your exhaust, but over all this product is excellent and improves the handling rapidly. Also the bars look nice from paint and emblem to the light wieght construction of Aircraft Grade 6061 Aluminum.
If you seeking more handling and performance, this is the way to go
And its not that expensive too
Old May 4, 2005 | 04:14 PM
kaigenx's Avatar
hmmm....i was looking at those last night and wondered if they were any good. Looks like a good buy now...thanks for the info!
Old May 4, 2005 | 04:41 PM
roneski's Avatar
Devil's Advocate
Interesting. Do they replace stock braces or do they just mount in their on spots?
Old May 4, 2005 | 05:45 PM
kaigenx's Avatar
It looks like they mount on their spots...
Old May 5, 2005 | 09:12 AM
JUAN's Avatar
The two rear braces mounts right on the spot and the front too, but the front you have to remove the lower black plastic cover (the one with many screws) inorder to make clearnce for the front brace, then optional if you want to restall the lower black cover back. I did?
Old May 11, 2005 | 01:30 PM
badtz's Avatar
does this fit the sedan? and does this actually help handling with stock suspension setup?
Old May 13, 2005 | 01:06 PM
JUAN's Avatar
After two weeks riding with GT SPEC Package,
I would have to grade it a A+ product.
Old May 13, 2005 | 03:23 PM
pdjafari's Avatar
Juan,
does this help in handling or on turns etc???!! i want sways but wanna know if these are also beneficial...
Old May 13, 2005 | 08:09 PM
headpaneer's Avatar
Can you be a little more descriptive about the handling improvements you notice?
Old May 14, 2005 | 07:37 AM
supsup's Avatar
where to get those ??
how much around?
thax
Old May 14, 2005 | 12:12 PM
kaigenx's Avatar
www.performancenissanparts.com
I think it's like 250 for all three bars.....i'd love to order these but I just ordered my wheels....
Old May 16, 2005 | 02:07 PM
JUAN's Avatar
The improvements are a little hard to describe in words, but I'll do my best. When your driving like around 50mph or more and you approach a turn or curve (the turn or curve may vary) you feel the G more stable in the front and rear too, and instead of the rear moving more to the side of the curve due to instability and speed, it really make’s the G stick more to the road and handling improves.
Old Jul 6, 2005 | 11:08 AM
KjbAlto's Avatar
So you added these bars along with new sway bars? Or you just did these bars instead of the sway bars? Do you think you will benefit from replacing the sways and adding these or is that overkill and repetitive?
Old Jul 6, 2005 | 03:15 PM
kaigenx's Avatar
i bet to get it all down you need a combination of these plus other suspension parts.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Claudiu
Sep 26, 2015 01:04 PM
