5mm wheel spacer
Old May 28, 2005 | 11:27 AM
graphite6mt's Avatar
5mm wheel spacer
thinking about a 5mm spacer to bring out my front wheel alittle. should i go wit h&r wit longer bolts or can i just get the $20 generic spacer?
Old May 28, 2005 | 01:21 PM
kenchan's Avatar
As long as the center hole of your spacer is a 66.1mm diameter version and
sits properly on the hub, you should be fine if only a 5mm spacer. You'll still
have about 4-5mm of the stock hub exposed making your wheels hubcentric.
tirerack.com has some nice spacers. talk to Alex over there.
Now, remember that our wheels are lug centric although they are hubcentric
to make them convenient for installation. If you do any track time, use
longer studs.
Old May 28, 2005 | 01:30 PM
dennis_said's Avatar
Hey Ken, how much spacer mm can be stacked until it's PUSHING it? YOu think 10mm would still be safe for daily FWY driving?
Old May 28, 2005 | 05:10 PM
kenchan's Avatar
on stock studs, 5mm is max. if u use longer studs you can do 5-20mm. If
u get too aggressive, ur going to prematurely wear the bearings.
Old May 29, 2005 | 12:11 AM
ZeroGen's Avatar
Omega Enthusiast
There was a previous post about this same topic.
Some guy was ranting about the physics of it all and when I asked details / data to back up his post, he got pissed off. I was amused.
Funny, when people really know their sh*t they do everything they can to help you out but others who blow smoke get offended at any inquiry about their info.
Old May 29, 2005 | 12:42 AM
IS300TOG35's Avatar
► Matt ◄
I have H&R Trac + on my front wheels, no issues. The Trac + spacers with extended bolts are 55 bucks and maybe another 30 for install (thats what i got charged).. so I dont see why you wouldnt want to go the safe route and get the longer studs.
Old May 29, 2005 | 09:09 AM
kenchan's Avatar
That's a nice option.
Old May 29, 2005 | 04:35 PM
codeflux's Avatar
you might want to read my thread on spacers: https://g35driver.com/forums/wheels-tires/52645-wheels-installed-using-spacers-good-bad.html
some good info there. you may reconsider using spacers.
Old May 31, 2005 | 11:45 PM
where did u get the h&r trac from?
Old Jun 1, 2005 | 12:16 AM
IS300TOG35's Avatar
► Matt ◄
http://www.optauto.com/index.htm?stocknumber=HR1065662
Old Jun 1, 2005 | 11:21 PM
thx
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
