Hmm, my left rear dropped a bit
Old Jun 8, 2005 | 09:55 PM
dennis_said's Avatar
Hi guys,
My left rear rim has gotten closer to the fender (I noticed it today as my car was parked)... I am on stock suspension, however it looks like maybe it is dropped on HTECHS...
The right rear is still the same.... could it be because of my sitting in the car that has caused the left rear to drop/settle a bit?
My friend said maybe it's a blown shock, but I do not see how this could have occured, please advise...
thanks!
Old Jun 8, 2005 | 10:21 PM
al503's Avatar
My left side is also noticeably lower. I have RSR Ti springs on but they're not the culprit (I changed the rears out side to side but the driver side was the same height).
It's not the shocks either. Shocks dampen. They don't determine ride height.
Old Jun 8, 2005 | 10:26 PM
Thanks for the reply al503, do you think it's just "one of those things" then?
I mean, now I'm looking at it, and it seems BARELY noticible...
Altho, now I'm ****... I was driving at < 5 mph, and I felt little bumps... altho it could've just been the road... or my suspension!! o_O
Old Jun 8, 2005 | 10:59 PM
khsonic03's Avatar
You know, I noticed the same thing on my sedan. I had 350z springs when I first noticed it, and now I have Htechs, and the same thing is present. Wondering if it is somthing built into the suspension.
Old Jun 9, 2005 | 01:51 AM
Is it on the left side for you too khsonic03?
Old Jun 9, 2005 | 02:24 AM
axiochris's Avatar
my rear left is lower too. im dropped on eibachs. WTF ????
Old Jun 9, 2005 | 08:35 AM
khsonic03's Avatar
Yes, left for me.
Old Jun 9, 2005 | 02:10 PM
kenchan's Avatar
Mine measured completely even left/right.
The lower progressive spring rates will tilt the car (H-Techs, S-Techs) but
your factory linear springs shouldn't.
I'd just add some shims to even out the corners. run a search on how
Gsedan35 did his to adjust ride height.
Old Jun 9, 2005 | 04:10 PM
khsonic03's Avatar
Both my stock and my current setup (350z H-techs---not progressive) had the same problem. And funny you should mention--I am going to be doing what G35sedan did anyhow, because with all of my stereo equipment, my rear sits too low for my tastes.
rezendvous420
May 31, 2020 01:26 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
joedaddy1
Jul 28, 2015 02:58 PM
