Help! Need DIY for spring installation
Old Jun 15, 2005 | 08:22 PM
vodkarocket's Avatar
Modded Member
Does anyone know if there is a DIY here (or anywhere else on the net) for a spring installation for our cars? I am planning on doing it tomorrow and want to make sure I don't mess anything up.
I tried searching, but with no luck.
Thanks
Old Jun 15, 2005 | 08:59 PM
wanalaugh74's Avatar
Thanks
I think Gsedan35 put together a real comprehensive DIY. You should PM or search with his name. He is the "Spring-Master"
Hope it helps.
Old Jun 15, 2005 | 09:02 PM
Hey found it for ya!! LOL Forgot it was in my subscriptions
https://g35driver.com/forums/brakes-suspension/6270-how-install-springs-struts-350z.html
Old Jun 15, 2005 | 09:37 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
here is my own write-up
http://www.g-owners.com/article_read.asp?id=25
i used g35sedan's write-up and tailored it a bit to the coupe.
hope this helps
Old Jun 15, 2005 | 10:48 PM
kenchan's Avatar
buy some cotter pins if you don't have any (2pcs needed, maybe not if you're
lucky).
Old Jun 16, 2005 | 11:52 AM
Modded Member
Thanks a lot for the DIY's. Pics will be up tomorrow, if I don't break something along the way... Wish me luck!
BTW, what are the "cotter pins."
Old Jun 16, 2005 | 01:27 PM
kenchan's Avatar
On your front sus, where the knuckle meets the a-arm, there is a nut you remove
to collapse the a-arms in order to remove the strut. Before you remove the nut
you need to remove a metal pin that is attached to prevent the nut from backing
out.
If you're lucky the stock one won't break off while removing. my case, it broke off.
Old Jun 17, 2005 | 12:53 PM
Modded Member
I am so angry right now.
I attempted the install with my buddy last night, and it turns out that the spring compressor I had was TOO LARGE. Not only could I barely get it into the wheel, but one I found the appropriate angle to get it in, I couldn't get all four mounting points onto the spring.
I am going to have to get a different spring compressor today and try again, but the DIY made the rest of the process EXTREMELY easy. I can't believe I paid shops to do this with my past cars...
Old Jun 17, 2005 | 01:43 PM
kenchan's Avatar
You can just rent one from Autozone if you have one near you.
snic09
Nov 8, 2017 01:46 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
yassy
Aug 9, 2015 07:31 PM
