Will 305/25-20" or 315/25-20" tires fit rear?
Old Aug 16, 2005 | 12:13 AM
Silver_G's Avatar
I have searched the forum and even though I seem to remember someone talking about 305mm wide tires in the rear for the coupe I cant find the thread. Does anyone have this setup? What is the widest that one can go in the back?
I've used some of the tire calculators on the web and while the overall diameter will be within 1/2" or so I am not sure that the suspension or body can accomodate that kind of width (rubbing?)
I currently have 275/30's in the back which i plan on changing...
Thanks in advance
Old Aug 16, 2005 | 01:05 AM
ashtangaz2001's Avatar
I agree with Smoked. I doubt 315's would fit. Viper size.
Old Aug 16, 2005 | 01:29 AM
waijai's Avatar
i.love.gold
I've seen 295 on 19's on a G coupe.
Old Aug 16, 2005 | 02:30 AM
kdiesl's Avatar
I have 20x11 inch lowenharts with 305/25/20 tires. My car is droped and dosn't rub. I took out the rubber lining inside the fender and had the fenders flared out. The rear of the car looks great the wide tires set it off. The only problem is that you have to be careful they pop easily.
Old Aug 16, 2005 | 08:08 AM
Silver_G's Avatar
What exactly do you mean by "flaring out" the fenders? Do you mean rolling the fenders with a baseball bat? If not how was it done? Any damage to the paint?
they pop easily.
What pops? Get a lot of flats?
I agree that the wider tires make the car look a lot more muscular. The overall diameter is slightly smaller however...
Sorry about all the questions. Thanks. Any PICS?
Cristian
Old Aug 16, 2005 | 09:18 AM
Finiti35's Avatar
FGC South Florida BOD
This is 305's in the back on a G (lowered)
And 305's on a Z (not lowered)
Attached Thumbnails Will 305/25-20" or 315/25-20" tires fit rear?-z-20s.jpg
Old Mar 23, 2006 | 04:53 PM
bjdraw's Avatar
So what was the general consesus, will they fit?
I thinking of buying
19x9.5 front with 275/30YR 19
19x10.5 rear with 315/25YR 19
The factory tires are ~28mm per inch in regards to width.
This setup would be 30mm per inch in the rear and 28.9 on the front, so the tires wouldn't look as stretched as the factory ones do.
The total hight is of concern in regards to fitment as well as ride quality.
The factory wheels are
572.6mm tall on the front.
580.6mm tall on the rear
The proposed ones would be
561.1 on the front
561.35 on the rear
I am thinking that the shorter overall height will help prevent the car from rubbing, but you will feel the bumps more because of the fact that the side walls are shorter. The widest tire I can find in a 35 series is 285 so the widest rim I could use to still not look stretched would be 10 bet perferibly 9.5
What do you think?
Old Mar 18, 2013 | 03:12 AM
George Alarcon's Avatar
i have 295/25/20 on my G35 with no problem stock suspension and im gonna go with 305 on my next set of tires
Old May 14, 2013 | 02:40 PM
purp35's Avatar
285 is the max youve seen? pff ive had 305/25/20 on a 20x10 with +3et and on tein s-tecs and they fit with no problem or rubbing issues, ofcouse i had my fenders flared out about 1.5 inches but i felt like i could of still gone wider.
my next set up im doing 345/25/20 on k3's 20x11 with +5 et on megan coilovers dropped about 1.3 inches. the wheels should come in by the end of this week
Old May 14, 2013 | 05:40 PM
sharkcityG's Avatar
he said that 7 years ago
Old May 15, 2013 | 07:19 AM
idrive_MD's Avatar
I ran a 285/30/19 up front with a 305/30/19 rear setup for over a year on 19x10+20 and 19x11+23. Camber was a touch aggressive for street but nice for track. Just a roll front and rear, no rub issues ever. When I get back in the game I am looking at going 295/front and 325/rear and no I do not have the power to take advantage of it so hate'away!
vitamin.v
Nov 7, 2019 06:10 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
BlackGee35
Jul 31, 2015 11:04 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
