Ok its getting close to new tire time, again, and I was wondering if I can get wider tires on my current wheels. As of now I have Volk SF Challenges in 19x8.5 up front and 19x9.5 rears wrapped in Toyo Proxes T1-S 245/35 ZR 19, 275/35 ZR 19. Would it be feasible to get some 255/35 and 285/35s on the same rims, especially the rear?
Quote:
Yes and yes. Your 9.5" rears will easily accommodate 285/35/19's and your 8.5" fronts will accommodate 255/35/19's. Originally Posted by PearlWhite03
FYI, if you go to Tirerack.com, choose just about any performance tire and then click on "Specs", it gives you all the different tire sizes available and a "Rim Width Range" for each size.
-T
Would running the 285 with 245 cause any problems with the VDC/ABS/odo/speedo? Reason being I don't really need the fronts yet, however my rears are starting to resemble slicks. I do plan on getting 255s up front when they are needed though.
Is anyone running the 255 and 285 on 8.5s and 9.5s?
does anybody know what the widest tires are that can fit on the oem 19s? front and rear????
FYI, i'm no pro whatsoever, but having a tire FIT doesn't mean it will perform the way it is meant to be, or even SAFE.
