question on rims and suspension
Old Nov 30, 2005 | 01:37 PM
newbieg35's Avatar
ok i have a 03 mt coupe..can someone tell me how much does the car go higher when a set of 19" rims is added with low pro tires to the vehicle?
2nd question is, can i see some pixx of coupes with aftermarket rims?dropped or not
Old Nov 30, 2005 | 01:41 PM
NAMVET's Avatar
Welcome to the site, I am also new here.
If you use the search and gallery areas, you will find what you are looking for.
There is a lot of great info here. Good luck
Old Nov 30, 2005 | 11:05 PM
Teeter's Avatar
The car doesn't go any higher (or lower, for that matter) when you add 19" rims unless you don't use the appropriate size tires. An increase/decrease in the total diameter of the wheel/tire will raise/lower the height of the car, so you want to compensate for the larger rim with a lower profile tire. Use the Miata calculator to figure specifics.....
http://www.miata.net/garage/tirecalc.html
-T
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
DimQ
Aug 14, 2015 02:04 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
