Are my tires TOO small?
Old Dec 7, 2005 | 07:40 PM
IS300TOG35's Avatar
► Matt ◄
i have 18x8.5 and 18x9.5 with the same tires dunlop m3s with 225/45/18 and 245/45/18. it works fine.
pics here
https://g35driver.com/forums/picture-share/77089-my-new-18-winter-wheels-not-56k-friendly.html
Old Dec 7, 2005 | 08:16 PM
BlazeMaster's Avatar
I thought the wider rear tires would help with RWD cars' handling.
Old Dec 7, 2005 | 09:19 PM
kenchan's Avatar
a little stretch is fine.
in snow you want to use the narrowest tire you can get on there....but
factory size is fine.
wider tires work best in dry conditions.
Old Dec 10, 2005 | 01:00 PM
eddwin's Avatar
Originally Posted by smokedhen
I heard that narrower tires do work better. why is that anyway?
wide tires have to push more snow aside than a narrower tire, and chances are greater of being stuck with the wide tire, while the narrow one can "slice" through the snow.
Old Dec 14, 2005 | 09:57 PM
G35Maxedout's Avatar
FS: OEM 18" W-n-T
By using a narrower rim and tire combo the contact patch is decreased and therefore increases the PSI, giving better traction.
You have the same amount of weight with a smaller contact patch, therefore more traction in the snow.
vitamin.v
Nov 7, 2019 06:10 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
derres
Aug 28, 2015 03:27 PM
