HELP AGAIN, i cant screw the lugz in!! QUICK
Old Dec 27, 2005 | 09:10 PM
anbakookie's Avatar
Ok, im a crazy newb, but i unscrewed the damn bolt that was attached to the brake disc, and now when i try to screw in the lugz on to the aftermarket rims, theres not space to put in my thin wall 21mm socket. I mean, the hole in the rim barley fits the lug in there, and on top of that u have to use something to screw it in?! how in the hell do you screw that sucker in? Do i have to get different lugz or something?
Old Dec 27, 2005 | 10:14 PM
jjyellow's Avatar
you probably need a set of tuner lug nuts
Old Dec 27, 2005 | 10:51 PM
didit70's Avatar
go to autozone or checkers or any autoparts store and buy tuner lugs... same thing happened to me... they're called spline locks or something like that...
Old Dec 29, 2005 | 02:36 PM
trebien's Avatar
Yep. Splines.
Old Dec 30, 2005 | 02:01 PM
kenchan's Avatar
stockers on the coupe are 19mm
you need to get ones that are 17mm.
Old Dec 30, 2005 | 05:38 PM
kenchan's Avatar
btw, after you torque up your lugs to either 80 or 90lbs/ft (your choice),
make sure you retorque them after driving 5-10miles.
lugs will settle and sometimes loosen up.
usually after this re-torquing, you won't need to re-torque again..but
im kinda **** about this and re-torque twice. 5miles then again around
20-25miles just to be safe.
Old Dec 31, 2005 | 03:20 AM
CarFanatic56's Avatar
what kind of aftermarket rims did you get?
Old Dec 31, 2005 | 09:19 AM
Mark350GT's Avatar
ehh i dont think you really need to re-torque them. With my volks, in order to get the lugs in i need a thin 19mm. I guess you can get those at autozone.
Old Dec 31, 2005 | 11:56 AM
kenchan's Avatar
mark-
Dealers's don't tell you to retorque because they are torquing in
excess amounts...like 100lbs/ft+. it can lead to other problems
including fatigued studs where it will snap easier under heavy load
while using stickier wider tires. but since most cars' lugs rarely
get removed (only during a flat or one of the long term service
appointment) that is why they can get away with using high
torque and not asking the customer to re torque. also, most
stock tires don't stick nearly as well as after market tires
anyway so less stress on the studs.
if you're planning to take care of your car and wheels and plan on
swapping wheels over the course of the year, use the correct
torque amount and retorque your lugs after each swap you do.
it only takes less than 2min to retorque your lugs...just do it.
you'll thank me for it later.
Old Dec 31, 2005 | 12:43 PM
G35Papa's Avatar
Thumbs up
Sorry, couldn't wait till later
<a href="http://imageshack.us"><img src="http://img390.imageshack.us/img390/1293/thankyou0nr.gif" border="0" alt="Image Hosted by ImageShack.us" /></a>
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
