Low Tire Pressure light
The last two days my car has the tire with a ! lit up and its P#ssing me off. I checked all the tires and they are all perfect, so why wont the stupid light go away?
Is it because its only 30 degrees outside?
no after I already drive it
To answer your earlier question, a tire will change about 1 psi for each 10 deg. F of ambient temperature change. It can also lose as much as 1 psi a month just bleeding air through the rubber.
Originally Posted by Manbir_Sandhu
we have tire pressure light in our cars? If so which year? i dont think i have on mine, 03.5
ok Ill check them before I drive it then. All tires should be 35psi right?
mine are 19s
mine are 19s
Checking the factory specifications on the door jamb is ok as long as you have the oem tires but sooner or later you're going to change the tires. Rather than depending on the sticker, locate the tire specifications ON THE TIRE. Look for the tire's maximum psi load.
Word of advice: Go by the car door sticker and stick to it!
Micale757
Lighting
Apr 8, 2020 10:46 AM
joedaddy1
Jul 28, 2015 02:58 PM
