How wide of a Tire to go with 18x10?
Old Feb 8, 2006 | 05:58 PM
Dan_K's Avatar
I was thinking 275's or 295's for the width. I want to make the sidewalls look flat like stock, not too curved in making the tire tread seem smaller than the wheel. What do you guys think?
Old Feb 8, 2006 | 06:01 PM
e420x's Avatar
Mod Junky!
275
Old Feb 8, 2006 | 08:36 PM
sen_jen's Avatar
Meatshake Enterprise
275 max. anymore and you wouldn't want to corner as you please due to sidewall flexing. personally, i'd go with a 265/35.
Old Feb 8, 2006 | 09:03 PM
Dan_K's Avatar
Hmm..the stock wheels are 18x8 and they use 245/35 in the rear. So, adding 2 inches only equates to 20mm of width? I thought you had to add to the width accordingly, since 25mm ~ 1 inch.
Old Feb 8, 2006 | 09:13 PM
sen_jen's Avatar
shucks, i forgot to mention that brands vary from sizes as well.
Old Feb 8, 2006 | 09:42 PM
jdj27x's Avatar
What about 295/30/19 on a 10.5" wheel?
Old Feb 8, 2006 | 10:10 PM
My350GT's Avatar
295's is prone to rubbing against your inner fender because of how wide they are. I would stay at 275 even on a 10.5 rim.
Old Feb 8, 2006 | 10:51 PM
sen_jen's Avatar
it can be done, but it wouldn't be worth the fender modifying, and the s.hitty handling due to flexing.
Old Feb 9, 2006 | 01:26 AM
Dan_K's Avatar
I forgot to mention, I will be using 25mm hub-centric spacers in the rear.
Old Feb 10, 2006 | 01:52 PM
spmc's Avatar
I have 10s in the back and am running 275 tires. For me, they are too stretched. For the tires to come out flush with the wheels, I think I am going to try 285s next.
Old Feb 12, 2006 | 06:41 PM
G-TWIN's Avatar
i think 285 as well. bfg kdw2
Old Feb 12, 2006 | 08:01 PM
Dan_K's Avatar
Another Question: The thicker the wheel the better? Or do you want less sidewall as possible? I was thinking of going with 285/45 R18 Michelin PS2's for 18's. Is 45 too thick?
Old Feb 13, 2006 | 01:30 AM
Disco_Monkey's Avatar
I have 275/35/19's on my rear 19x10.5.
I was going to get 285/35 or even 275/40 but I was advised against it by several racers.
Old Feb 13, 2006 | 01:43 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
a 45 series tire is too thick for a 285 width or even a 275 width. I'd stick with a 285.40.18 at the MAX.
-GP-
Old Feb 13, 2006 | 04:33 AM
Dan_K's Avatar
What was the reasoning? Because of sidewall flex? Could you post a pic of your rear wheels? Thanks.
Ya, after thinking about it 45 seems too thick, and the fact that no one pretty much makes one. I was thinking of 285/40 R18 101Y BFGoodrich g-Force T/A KDW 2. About $230 at tirerack.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
