Will It Rub, Help Asap Please
Old Feb 11, 2006 | 11:04 PM
Nickk6's Avatar
Originally Posted by skeleton_cru
This is what I use when calculating tire sizes.
http://gs.tolan-hoechst.com/tirecalc.htm
You plug in your stock tire size and then the tire size you are considering. Make sure to check the fields that says "Tire height (inches):". The closer these two are the better. This site will also calculate the speedo error.
Yeah I did this with the miata tire calculator, I am aware that different brands in the same size can be a different size. The 275/30 and 275/35 are close to OEM, but of course one is up and one is down. 275/35 sounds good because its meaty, but it also might rub, 275/30 sounds good because less chance of rubbing, but than I have a thin tire on an expensive rim.
Anyone with a good suggestion?
Old Feb 12, 2006 | 12:26 AM
skeleton_cru's Avatar
Sedan
I would definitely go with the 35 series tire. The 30 series is way too thin.
Old Feb 12, 2006 | 08:27 AM
jimmyc13's Avatar
So I notice some of you mentioning to run 275/35 in the rear...and I presume you're saying this because you know it works/doesn't rub? I've been trying to get an answer on this recently due to my dilemma (see post here: https://g35driver.com/forums/showthr...44#post972444). Nick - sorry for the thread jack, but it may help you too. Thanks.
Old Feb 12, 2006 | 07:43 PM
G35_TX's Avatar
Originally Posted by Nickk6
I am going to buy VOLK GT-C's. The size is 19x8.5F and 19x9.5R. Tire size, 245/35/19F and 275/30/19. WILL I RUB. Some poeple say yes and some people say no (well the places selling the rims). I plan on buying them today if they do not, so I am hoping for a quick responses.
Front offset: 39
Rear offset 37
THANKS IN ADVANCE
Front will not, rear is questionable. I have 38mm offset, with the same tires and wheel sizes. I rubbed stock height in the rear only until I bent the inner lips in and it fixed the rubbing issue. 37mm offset is questionable.
Old Feb 12, 2006 | 07:44 PM
G35_TX's Avatar
Originally Posted by jran76
The front will be fine, I think there is a decent chance you will rub on the back. I think you need to get up to a +42 if you are lowered with proper alignment. If you are not lowered, you may be ok. The are some people running +38 9.5's (HP Evo's), here is G35_TX's thread.... The general concensus is no lowering=ok, lowering=rubbing.
Linky: https://g35driver.com/forums/showthr...hlight=rubbing
Actually stock height it will rub. I did. I just bent the inner lips in a little and problem solved. Lowering would increase the camber on the rear, which will decrease chances of rubbing. Once I bent the lip, lowering is the way to go now for sure.
Old Feb 12, 2006 | 09:54 PM
Nickk6's Avatar
I have a 45 rear offset and 42 front offset. I got the LE37s instead.
Old Feb 12, 2006 | 10:04 PM
Nickk6's Avatar
Don't apologize, I don't mind the extra info.
I think the thicker tire is a better choice since it will probably protect the rim better and the place where I bought my rims said they would cut the inner lip in the fender. So I may do that if it rubs after lowering.
EDIT
Found this
275 35 19 26.58"
235 45 18 26.33"
Definatley going with the 275/35/19.
Old Feb 14, 2006 | 01:34 PM
jimmyc13's Avatar
EDIT
Found this
275 35 19 26.58"
235 45 18 26.33"
Cool . Also is better because it fills the wheel well more (than if you went w/the 275/30's (OD would be LESS than stock tire OD).
Old Feb 14, 2006 | 09:23 PM
Nickk6's Avatar
Bridgestone SO-3 in 235/45/19 is way too thin for anyone who uses 275/35/19rear.
Old Feb 14, 2006 | 09:32 PM
Nickk6's Avatar
My car with 19" LE37s in Gunmetal
My cousins car with 19" GT-Vs in Diamond Black.
Will be getting better pictures, later
And I rub apparently with no one in the back seats. So...fenders will be cut, do I need to worry about rust?
Old Feb 16, 2006 | 12:43 PM
jimmyc13's Avatar
So what are the final specs. w/ tires? And why CUT the fenders? Why not just get them rolled?
Old Feb 17, 2006 | 07:22 PM
Nickk6's Avatar
Rear 19x9.5 Offset 45
Front 19x8.5 Offset 43
Rear Tire: 275/35/19 Potenza S0-3
Front Tire: 245/35/19 Potenza S0-3
I fvcked up the part where I was suppose to use a 245/40/19 in front, so no VDC problems, but it looks like the tire in front is too small.
Rear fenders need to be cut because the tire is sticking out about an 1/8 of an inch and when I go up an angled driveway the tire rubs. I was going to roll them, but F1 Motorsports told me that than can warp the fenders.
Old Feb 17, 2006 | 07:26 PM
G35_TX's Avatar
Listen to me. Do not CUT your fenders. I did a lot of research on this and a lot of people on the net that have CUT them had never ending rust problems even after they coated it with primer and paint. It's in a bad place to cut. BEND the lips up with a baseball bat! I did it on my G35 without a problem. I was scared at first as well. But you don't have to bent the lips up much. I went from a 3 oclock up to a 2 oclock angle on that lip and now I clear without problems. I didn't bend them all the way up since it wasn't needed. The paint did crack in a few spots but touch up paint took care of that.
Old Feb 17, 2006 | 08:59 PM
Nickk6's Avatar
Thanks for the info. You convinced me. My friend tried using a baseball bat on his GT Stang, well it didn't work out well, he had the paint crack as you mentioned. Plus we had a hard time getting the angle. What about the machine that does it, that hooks up where the wheels goes. I don't really want the paint cracking either.
I am thinking when I lower it, its gonna be very mild in the rear. Do you have any close ups ?
Old Feb 18, 2006 | 12:09 AM
  #30
G35_TX's Avatar
Paint will crack no matter what unless you can get enough heat to make the paint flex.
The bat method, if you look at the bat it is fat at the top, and skinny at the handle. You stick the fat end into the wheel well, if needed jack that part of the car up some. Work your way from the skinny end up to the fat end and rolling the bat across the top of the tire against the wheel well lip. Pushing down on the bat to put pressure up at the fender. Slowly but surely this will bend it up some.
