Will It Rub, Help Asap Please
Old Feb 18, 2006 | 02:18 AM
  #31
skeleton_cru's Avatar
Sedan
Originally Posted by G35_TX
Paint will crack no matter what unless you can get enough heat to make the paint flex.
If the paint cracks don't you still have to worry about rust?
Old Feb 18, 2006 | 04:50 AM
  #32
Nickk6's Avatar
I believe the primer holds together, but I could be mistaken
Old Feb 18, 2006 | 11:25 AM
  #33
G35_TX's Avatar
No, because where the lip is there are two plates of metal welded together. If you cut them you open up both. You can't completely get that sealed off again and primered over it. There are weld joints that hold it from moving. If cut the weld joints are not longer there and the sheet metal of the car will rub against each other and scrape the paint/material off and it will continue to rust. There is a inner body panel and outer. Both are welded together there.
Bending it up and fixing a paint crack is like fixing a chip on the paint.
Old Feb 18, 2006 | 07:30 PM
  #34
Sedan
Oh OK, thanks for the explanation.
Old Feb 19, 2006 | 12:38 PM
  #35
jimmyc13's Avatar
Nickk6 - Isn't it better to just take a hit on this one, put your 275/35's up for sale and buy some 275/30's? In the end, yes, you will obviously lose a small amt. of $, but it's better than having to "baseball bat" your fenders....no?! Just my thought.
Old Feb 19, 2006 | 08:37 PM
  #36
abcdang's Avatar
even if you get it not to rub with normal driving, what happens when you hit a bump or pot hole? will the angle of the suspension avoid rubbing, or will it hit?
Old Feb 19, 2006 | 10:45 PM
  #37
G35_TX's Avatar
Won't matter. I got to test it on our big Rampage Bull cruise. My back end of hte car bottomed out on the bump stops several times and no rub.
Old Feb 19, 2006 | 11:56 PM
  #38
Nickk6's Avatar
I rather figure out how to fix the rub with the 275/35/19 than use a small tire and risk even more damage to the rims. It is barely rubbing, and as G35_TX mentioned, he stopped rubbing after slightly bending the fenders. I am going to lower the car with proper camber and then see how much needs to be bent in.
Ouch, what is your suspension setup?
Old Feb 20, 2006 | 08:28 AM
  #39
G35_TX's Avatar
Stock. Let's just say were going fast, very fast wtih a few dips that were next to each other. I also had about 150lb of stuff in the trunk at the time too.
Old Feb 20, 2006 | 05:21 PM
  #40
Nickk6's Avatar
Are you gonna upgrade by any chance. I am not looking to "slam" my car, I would like to even out the front with the rear. I know my tires are a tad small up front, but there is still a large gap there to begin with.
I probably need about a 1.5" front and .5" rear drop, is any spring available that can handle this without giving the car bad handling characteristics?
Old Feb 20, 2006 | 06:38 PM
  #41
G35_TX's Avatar
Yes. I plan to drop my car with some springs. I have yet to decide what springs I want. IllG35 had some nice springs on his.
He said these were the ones he had: http://www.slickcar.com/productdetai...ProductID=3317
Old Feb 20, 2006 | 10:50 PM
  #42
Nickk6's Avatar
I dunno...those do not mention the drop. How much are you looking to spend on your suspension? Seems like we are both in the same boat as far as suspension/rubbing issues.
My lovely gap
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
alinero718
Sep 27, 2015 09:35 PM
