Should I go 18 or 19 inch wheels on 03 sedan?
Old Feb 18, 2006 | 09:45 PM
seabass's Avatar
Which size would you go and why? Thanks
Old Feb 18, 2006 | 10:09 PM
TheTrance's Avatar
from what ive seenm 19s are for the looks whereas 18s are for performance
Old Feb 18, 2006 | 10:12 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Most 18s will be lighter than 19s and the price of 18" tires are alot more affordable than 19" tires.
So, since my G came with 17s, I would do 18s. I have concluded that 19s would be too heavy, too expensive(mainly tires), and have too rough of a ride. The tire price is especially important--when running staggered setup--you can't ROTATE so you got to PROLONGATE! And with Falken, Pirelli, Avon, Nitto offering 245/40 and 275/35 18s from 136-200 compared to 236-336 in 19s that could save you 500+ bucks.................... and on an affordable set of wheels that could be 1/2 the price of the wheels. On more expensive sets 15-25% of the wheels.
Old Feb 18, 2006 | 10:32 PM
perry05G35's Avatar
You can find affordable 19" wheels and tires out there you just have to be a smart shopper. As for staggard wheels if someone already has a problem with paying $200+ for wheels they shouldn't go staggard
Old Feb 18, 2006 | 10:34 PM
seabass's Avatar
What are the stats and/or measurements on the 18s and 19s that would fit the 03 sedan?
Old Feb 18, 2006 | 10:44 PM
perry05G35's Avatar
In the front the widest you can go is a 245 in either 18 or 19
In the rear the widest you can go is 285 but most go 275 18 or 19
As far as profile it all depends on if you plan to get springs but to stay close to your current tire diameter you should go with either a 40series or 45 series 18 or 19.
Old Feb 19, 2006 | 02:49 AM
Texan1's Avatar
no problem--you just have to be smart like you say--I avg. 7k mi a yr--so staggered is no threat to me. But the best of the best for a set of 18s are 800-900 bucks--and 19s 1300 bucks. When it comes time to change tires, it would be nice to save 500 bucks--nuttin wrong with that.
Old Feb 19, 2006 | 04:25 AM
perry05G35's Avatar
Ahh I check eBay and do searches on google for the high end brands just to get an idea of what to pay my current setup costed me 1400 including shipping there are good deals out there you just have to find them.
Old Feb 19, 2006 | 09:47 AM
jimmyc13's Avatar
Originally Posted by Texan1
no problem--you just have to be smart like you say--I avg. 7k mi a yr--so staggered is not threat to me. But the best of the best for 18s are 800-900 bucks--and 19s 1300 bucks. When it comes time to change tires, it would be nice to save 500 bucks--nuttin wrong with that.
Falken GRB-451's - 245/40/19.....$189 each on most websites....A vendor on this forum quoted me a price of $730 (for all 4 tires) shipped to my door here in MA.....and they have a high UTQG rating (260 or 280). It's all about shopping around/doing research to find good deals (like Perry said).
Old Feb 19, 2006 | 01:21 PM
Texan1's Avatar
Bet you wont find a 275/*35*/19 in Falken Azenis or Grbs. If you want to run 245/40 front and 275/35 rear--you have to move up to a more expensive tire.
If I go with an 18" wheel, I can get the Falken Azenis in 245/40 and 275/35s
Old Feb 19, 2006 | 01:37 PM
jimmyc13's Avatar
Very true (tire size wise)....Toyo T1-R's can be found $220 for 245/40/19's, so not that much more. Though running 275/35/19's will rub on the rear of the sedan (as recently discovered), so it's a moot point for me.
Old Feb 19, 2006 | 01:53 PM
kevink's Avatar
What is wrong with the factory wheel size again?
Other than that, at some point, I've already scarred one tire from it being as low profile as it is, I don't know why you would want to go lower.
Old Feb 19, 2006 | 01:57 PM
Texan1's Avatar
19x8.5 +35mm 245/40/19 Front
19x9.5 +45mm 275/35/19 Rrear
If you run the correct offset it should not rub. Are you saying regardless of the offset 275s will rub
Old Feb 19, 2006 | 02:02 PM
Texan1's Avatar
I would like to have a look similar to the BMW 330I sport in terms of the wheel size,tire size(width and aspect ratio), fender gap, and lateral positioning of the rear wheel--you cant do that with stock 17s with out major drop, and spacers and shoe-horning a wider tire in the rear and that is not safe to me.
Attached Thumbnails Should I go 18 or 19 inch wheels on 03 sedan?-f34_cw.jpg   Should I go 18 or 19 inch wheels on 03 sedan?-66.bmp   Should I go 18 or 19 inch wheels on 03 sedan?-78.bmp   Should I go 18 or 19 inch wheels on 03 sedan?-67.bmp   Should I go 18 or 19 inch wheels on 03 sedan?-g-side.jpg
Old Feb 19, 2006 | 03:04 PM
kevink's Avatar
A person could argue that, if you want a BMW, maybe you should buy one
