225/50/r17 or 225/55/r17 for winter ??
Old Feb 19, 2006 | 01:16 PM
ericsherbrooke's Avatar
I have a 2004 m6 coupe, I ride on stagered blizzak LM-22 on OEM wheels right now and it's not really great in snow...
I want to have a 17 inches setup for next year, I just found some good used 225/50/r17. I was looking for 225/55/r17 all around, I know people running their coupe on that.
Will I be fine with four "not stagered" setup of 225/50/r17?
Anyone running on that?
Thanks!!
Old Feb 19, 2006 | 01:30 PM
Msedanman's Avatar
O.F. Administrator
Thanks!!
I ran 225/55/17's all 'round on my coupe and it was fine. You won't have any trouble with the 225/50/17's either.
C.
Old Feb 19, 2006 | 06:09 PM
D87's Avatar
D87
C.
I asked on another thread but no one seem to have any answers. I have the stock 235/50/17 and 225/50/225 original tires and I want to buy new tires - 235/45/17s and 225/45/17s.
The TireRack.com fellow insists that by doing this I may set off the VDC and the system won't work properly. Should I listen to this advice or is he just trying to push his recommended tires?
Thanks!
Old Feb 19, 2006 | 07:17 PM
Msedanman's Avatar
O.F. Administrator
Those #'s calculate out to about a 3.5% difference in circumference/revolutions per mile.
That's very close to upsetting the VDC. Tough call.
C.
Old Feb 20, 2006 | 12:01 AM
qlaval's Avatar
Thanks!!
I'm presently using the same setup as you, LM-22 on 18".
Not impressing at all as you already have noticed...
Your best choice would be to put 225/50R17 (FRONT) and 225/55R17 (REAR)
That way the VDC will still give you an appropriate safe reading in case of an emergency.
As for running on the same size all around.
I asked 4 different dealers.
All except one dealer said to keep the staggered setup untouched.
Since it was not unanimous I did called Infiniti Canada.
Their answer was do not change the staggered setup as this could interfere with the VDC & ABS.
More this could be a valid reason to void the motor/transmission warranty should they ever had a problem...
(I would like to see that in a court of law... Still, better safe then sorry)
Old Feb 20, 2006 | 12:20 AM
D87's Avatar
D87
C.
Wow, I guess those guys were serious, thanks dude. Avon M500s it is!
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
