Something wrong with my tires... ?
Old Feb 22, 2006 | 02:46 PM
gmoney1227's Avatar
I just noticed something and want to know if that's the way it is supposed to be. I have a G35 6MT, and I just noticed that the back tires, when looking at them straight on from the back of the car, don't look completely vertical. They don't look straight up and down, they actually look tilted inward a bit. Is that normal?
Or could that have happened when I curbed my right real wheel?
Old Feb 22, 2006 | 02:52 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It's called negative camber, our car has it from the factory, there is a factory rear camber adjustment but its not enough to make the wheel perfectly straight. If you want to get the wheels to be straight you need to buy a rear camber kit. you can get it at performancenissanparts.com If you look at the front tires it'll be the same, might as well do both front and rear camber kits while your at it.
-GP-
Old Feb 22, 2006 | 02:55 PM
gmoney1227's Avatar
Okay, thanks for that info. Good to know. Now, is there any NEED to really do that? What are the benefits? Thanks Gdup35Sedan.
Old Feb 22, 2006 | 04:03 PM
Q45tech's Avatar
PERFORMANCE Tires are designed to create optimal traction with a negative 0.5- 0.7 degree camber to precompensate for camber changes underload.
What is important is not what is happening sitting still but what happens at speed turning.
An alignment is setting suspension WRONG sitting still so that it is right rolling and turning.
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
