Tire pressure sensor and non OEM wheels
Old Mar 8, 2006 | 11:54 AM
LTQDustx's Avatar
I am looking to purchase new wheels for my 05 coupe and have tried searching but did not get a clear answer so am asking it here. If I purchase new wheels how will the tire pressure sensors work? (or they won't?) Will I just have to drive around with the tire pressure light on?
Thanks
Old Mar 8, 2006 | 12:21 PM
maaloxx's Avatar
^+1! Bump on this one!
Old Mar 8, 2006 | 12:38 PM
TheKnite's Avatar
I asked this question before, and also didn't get the answer from people with aftermarket wheels on. According to my dealer, I do not have sensors in my OEM 18s that I bought used, and my light is usually off. It went on twice during hour long trips, but it is off once you turn the car on again. So to my understanding when all 4 sensors are missing the light is off. Hope somebody verifies this.
Old Mar 8, 2006 | 12:44 PM
MahdiG35's Avatar
G RIDIN
I want to know this also.
Old Mar 8, 2006 | 12:51 PM
G35MC's Avatar
Me 2, i have snow wheels, and tire pressure light comes on when i drive the car for around 20 miles or so, and stays on.
Old Mar 8, 2006 | 12:55 PM
louielou's Avatar
I've got an 05 sedan and I haven't had my light come on yet with my aftermarkets.
You can have the TPS removed from your old wheels and put in your aftermarkets.
They might need to be re-calibrated at the dealer for the correct PSI trigger. (Im guessing on this)
Old Mar 8, 2006 | 01:23 PM
Jee_35's Avatar
the TPS doesn't work with my Volk SF C's, for the first week, the tps would go on and off randomly, now it just stays off. From my understanding, it has something to do with the valve stem of the wheel, but.. not 100% sure. I know that the TPS doesn't work with my volks tho
Old Mar 8, 2006 | 01:24 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The TPMS only works with some aftermarket wheels. It all depends on if the TPS sits on the wheel the same as the stocks. If you're lucky they will fit. Most of the time they wont fit though. Most people havent had a problem with their light remaining on constantly so you shouldnt have a problem.
-GP-
Old Mar 8, 2006 | 05:09 PM
jd2k1's Avatar
TPS works fine on my RacingHart J5 PRO 19" albeit a bit TOO sensitive. Does anyone know if we're supposed to use the same pressure on aftermarket wheels/tires as the stock?
Old Mar 9, 2006 | 08:37 AM
G35_TX's Avatar
Thanks
They are just moved over to the new wheels like my current ones are. Discount took them out of my factory ones and installed them in my new ones.
Old Mar 9, 2006 | 08:46 AM
g35driver05's Avatar
I have snow tries one.. and the TPS light nover came on i have drivng about 2,000 miles on these.
Old Mar 9, 2006 | 09:47 AM
k67p67's Avatar
I'm on my second set of aftermarket wheels. First set were NAD 20" and current set are Volk 19". The shop transferred the TPMS sensors from OEM wheels to each set of aftermarkets. No problems. TPMS triggered once when tire pressure dropped below 29 lbs. due to nail in tire.
Old Mar 9, 2006 | 09:57 AM
da mayor's Avatar
I got the dealership to throw on 20" Zenetti 5's on a coupe w/ TPMS and works fine with no issues having the light come on.
Old Mar 9, 2006 | 10:16 AM
FI'ed G's Avatar
I'm getting my wheels from F1 and they'll do all the mounting and balance, did all guys here with after market wheel transferred their TPMS sensors ?
Old Mar 9, 2006 | 12:04 PM
LjN_728's Avatar
Is there is fee to transfer the TPMS sensors at the shop or is it a simple procedure?
