What aftermarket wheels work with stock Tire Pressure Sensor ?? POST THEM HERE!!!
Old 03-27-2006, 02:57 AM
MahdiG35's Avatar
G RIDIN
Please post aftermarket wheels that work with the stock Tire Pressure sensor??
Thanks
Mahdi
Old 03-27-2006, 02:37 PM
MahdiG35's Avatar
G RIDIN
Old 03-27-2006, 02:48 PM
ttrank's Avatar
Grocery getter
20" Zenetti Fives work fine.
My friend that is a manager at Discount tire said that just about all aftermarket wheels should work fine with our sensors as long as you install them right.
Old 03-27-2006, 03:26 PM
pdjafari's Avatar
hmm ive heard that wheels w/ a deep lip the TPS will not fit onto. I also know the Volk CE-28N WILL work with the TPS...i believe Vleo has a set of these wheels in bronze...
Old 03-27-2006, 09:26 PM
vrsc's Avatar
Our TPS will not work Volk Racing GT series wheels. The valve stem is completely different because it come out of the center and make a right angle out.
Old 03-27-2006, 09:27 PM
jdj27x's Avatar
You can however get the wheel drilled, to allow for the tps. I decided against it, the tps system isnt that accurate anyway.
Most of the time when the tps comes on, you already are aware that an issue is present.
Old 03-27-2006, 09:36 PM
MahdiG35's Avatar
G RIDIN
I don't really car about if it works or not, I just don't want the light to be on all the time and be beeping all the time. I heard they beep for like 45mins everytime you drive the car.
Mahdi
Old 03-27-2006, 09:39 PM
jdj27x's Avatar
You actually got it backwards mang.
I have had my wheels for 500 miles and havent seen a light or a buzz EVER....
The light only comes on after 45 Mins OF NON STOP DRIVING.
Old 03-27-2006, 09:49 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Tire pressure sensor...........they work!!
When I had my Volk GTC's installed I took them out
of the factory wheels and put them in the Volks. A
little strange a first because there in the center of the
wheel. After driving on my new wheels for a while
my sensor went off.....I found a sticker or the inside
edge of the r/f wheel causing it to leek...easy fix.
But you see, they do their job.
Old 03-28-2006, 12:15 PM
mykmar10's Avatar
I have Volk Progressive wheels and have not had a problem with the TPS, it works the way it was intended to.
Old 03-28-2006, 09:11 PM
WhosUrBuddiee's Avatar
I haven 19" Asantis and they work, except after like 40-60 minutes of nonstop driving.
Old 03-28-2006, 11:56 PM
MahdiG35's Avatar
G RIDIN
dose it beep or just the light comes on??
Mahdi
Old 03-29-2006, 12:52 AM
k67p67's Avatar
19" Volk GT-7s. 8.5"/9.5" +23/+24
Work perfectly. Only triggered once and that was because a nail in the tire dropped PSI below 27 lbs.
Old 05-08-2006, 01:14 AM
GReddySetGO's Avatar
For those of you with Volks, you had to get the rims drilled to accept the TPS?
Old 05-08-2006, 02:01 AM
norcal_chan96's Avatar
No drilling for me... I have the VOLk GT-C's and they work fine with the TPS... I just had them installed last week... No problems yet...
Quick Reply: What aftermarket wheels work with stock Tire Pressure Sensor ?? POST THEM HERE!!!
