Ordered my new wheels/tires today.
Old Apr 26, 2006 | 01:51 PM
G35_TX's Avatar
From Tirerack. I am getting the Kosei K1 TS Grey in 18x8 40mm (16.5lb each!!!!!) semi-forged with the same procedure Volk uses. Also got the Goodyear F1 GS-D3 tires in 245x45x18. I am gonna be a sticky sedan when I need traction! They may not be the staggered or big offset deep wheel dish look some of you like. But I wanted performance and handling so I needed to keep the same tire/wheel size all around to do this properly.
No one else on these forums has done this combo, I am going to be the first .
So lets calculate a few things here....
Stock 48-49lb each with tires.
My first aftermarket set 53-54 lb with tires.
New set 43-44lb with tires.
So yes I am loosing a lot of weight! (The right type of weight), now if I could only do the same for myself! hahha.
Old Apr 26, 2006 | 09:39 PM
Andy2434's Avatar
I like the look. Post up when you have them installed.
Old Apr 26, 2006 | 09:44 PM
codeflux's Avatar
very spartan looking wheels. i personally prefer a little more bling (LE37T) - but it will look great on a black G. post pics!
Old Apr 26, 2006 | 10:14 PM
GTR_Boy's Avatar
Nice! Now you're ready for the track!
Old Apr 26, 2006 | 11:41 PM
truplay8's Avatar
THE BATMOBILE
should look stealth
Old Apr 27, 2006 | 02:26 PM
g35doc's Avatar
Why not 245/40/18 for the front if you wanted the same width front and rear?
Old Apr 27, 2006 | 02:32 PM
Jeff92se's Avatar
Red Card Crew
Nice Russ. Just a note. Your tires weigh 29lbs each. So 16.5+29=45.5 lbs. Still lightweight though!
Old Apr 27, 2006 | 02:34 PM
G35_TX's Avatar
Thanks. Since every scale is different I plan to weigh my stock ones and then the new ones after that on the same scale to really tell how much a difference it really changed.
Old Apr 27, 2006 | 02:35 PM
G35_TX's Avatar
245x40x18 and 245x45x18 are basically the same width, just the height is different. I rather go larger than smaller so my wheel well gap doesn't look so big!
Old Apr 27, 2006 | 02:39 PM
rcdash's Avatar
Just curious why you didn't pick lighter tires? (is this a balance between cost vs. traction?) Does the PS2 have any real competition in dry traction & weight combined?
Old Apr 27, 2006 | 04:13 PM
G35_TX's Avatar
Well, I wanted a real good performance tire, one of the best. And usually with such a good tire you have to add the weight because of how strong the tire has to be.
I could have gotten some Continental Sport 2 which are the lightest tire of the bunch at arouund 26lb but there ratings are not that great.
Old Apr 27, 2006 | 04:35 PM
al503's Avatar
Wow! I can't believe those wheels are that light.
I'm getting Volk Progressive Spoke wheels in 18" for my next ride and they're just around 18 lbs.
Nice choice.
Old Apr 27, 2006 | 08:30 PM
transportchef's Avatar
Post up pics when you get them. They would be a first for me also. Looks like it would be decent though. Had no idea your 1st setup weighed that much.
Old Apr 27, 2006 | 09:28 PM
superdds's Avatar
congrats on the wheels...i promise i wont jack this thread.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
