Double din/Climate controls question.
I have a quick simple question regarding OEM climate controls
I know they cannot be used with double din kit (that's why all double dins come with controls)
The question is why?
Are they like a part of entire facia thing and cannot be separated from the rest of the stuff?
I had my radio out and apart long time ago and cant remember if they are removable or not.
I'm sure you audio guys know the answer to that question.
https://g35driver.com/forums/audio-video-electronics/224099-reason-why-you-need-jdm-ac-controller.html
This pretty much explains it.
It can't truly be separated.
How about my Macgyver idea of JDM double din.
I'm thinking of getting Metra double din kit and converting it to JDM double din.
I want to cannibalize Bose radio for climate control buttons and modify Metra kit aluminum trim to accept those buttons that I plan to mate to IC board that comes with Metra climate controls.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
It sounds like a "fun" challenge to put together. If you sent the parts, I'd give it a go.
that's fantastic.
Thanks for the offer.
I'll get the Metra kit and see what is the situation is with the buttons. If it's too much for me to handle I'll defiantly reach out to you.
On a temperature **** though, I thought of soldering it out of the OEM and putting it on to metra to retain the spin action. Bun once again though, this is just wishful thinking, I need to get all of that stuff out and taken apart first to see what is what.
that's fantastic.
Report on my Macgyver idea.
In short: IT AINT GONNA WORK.
as you can see on the pictures that buttons are completely different. Re soldering them is not an option as Metra buttons are part of the board.
As far as cutting OEM trim to accept Metra buttons is doable but won't be easy. In order to eliminate (cut out) all OEM buttons the cut out window will be too big for DD stereo so top 4 round buttons on top of the CD slot will have to stay there and you have to cut out from CD slot down to create a window. Even in this case window will not be proper size because slot for CD is wider than opening for DD stereo. So it is a possibility to hack the OEM trim to accept Metra buttons, but it will not be pretty.
Larger DD hole could probably be addressed by different spacer brackets that you can get for DD stereo.
Verdict:
Converting OEM buttons to Metra kit IMPUSIBUR
Converting Metra buttons to EOM trim possible, but requires lot's of hacking.
Another option would be is to purchase JDM buttons (as they are sold separate from the trim) and hack the OEM trim to take DD stereo.
Verdict:
Verdict:
Verdict:
Edit:
This image had me thrown off, until I realized you were holding the board upside-down, with the temp buttons to the left.
It looks like the buttons all line up close enough:
I'd still give it a go, at least it looks like the 03-04 and metra line up pretty much perfectly with the factory buttons.
It still seems to line up just fine. With mounting at the proper distance, and those conductive nubs from the rubber on the back, all the buttons should work. I'd have to look a little closer at the wheel to try and get that to work. An option would be to make the wheel only turn a few degrees in either direction, solder in a couple microswitches that link to the board so holding left or right closes the connection across the bottom and top, respectively.
Since the metra seems to just respond to connections across the top or bottom pads to make the connection, you could probably find something that generates a connection across the top when turned one direction and across the bottom when turned the other way to keep it more like stock operation.
The offer to try and work this is still on the table, I just need the old trim and the metra board.
NATH_19 (09-30-2014)
I'll make it happen within next few week.
I'll be taking my radio out to do the Kindle Fire HD6 setup in a couple weeks once that ships out anyway, might as well test the climate controls while everything's accessible.
