Help troubleshoot Amp
Polk audio mm 900watt amp and mm components.
Guys, so as of lately I have been having this noise in my speakers. Its worse on driver side. First I thought it was a lose connection but after I took one of the speakers straight to the amp without the xover. I have the attached sound. Its a lot louder in the recording but its still audiable when the radio is on. A weird thing too is if I tap the speaker, noise goes away until I turn it on again.
I tested all the outputs. Its definitely worse on my front left channel. The rear channels, its hardly noticable.
I checked all the gains and they are barely 1/4 turn to max.
https://soundcloud.com/digitaldeviant/amp-noise
So, this didn't solve the problem. So here is an update.
Background:
I currently have a Polk Audio 900w digital amp with polk audio MM components. All wiring is separated from power, ground and RCAs, including relay for remote turn on. All speaker wiring is crimped, head shrunk and terminated. Ground is on a factory grounding point which is clean (and tested). I have tested this with both factory wiring and clean wiring and get the same results.
Issue:
Car is in the "on" position. Amp turns on (rca inputs have been disconnected). I can hear the amp turn on thru the speakers. I have provided a sound link to listen. It's at the 10 sec mark.
https://soundcloud.com/digitaldeviant/amp-noise-2
After that, the static continues slightly thru most speakers. However, my drivers side front is worse. A weird thing too is if I tap the speaker (drivers side) when it's making this noise, it stops in that speaker. Below is the sound from that speaker after the init sound is gone and this one remains. This is at the 8 sec mark.
https://soundcloud.com/digitaldeviant/amp-noise-3
Any advice / help would be appreciated because I have been chasing this down for two weeks now.
Background:
Issue:
So, this didn't solve the problem. So here is an update. Background: I currently have a Polk Audio 900w digital amp with polk audio MM components. All wiring is separated from power, ground and RCAs, including relay for remote turn on. All speaker wiring is crimped, head shrunk and terminated. Ground is on a factory grounding point which is clean (and tested). I have tested this with both factory wiring and clean wiring and get the same results. Issue: Car is in the "on" position. Amp turns on (rca inputs have been disconnected). I can hear the amp turn on thru the speakers. I have provided a sound link to listen. It's at the 10 sec mark. https://soundcloud.com/digitaldeviant/amp-noise-2 After that, the static continues slightly thru most speakers. However, my drivers side front is worse. A weird thing too is if I tap the speaker (drivers side) when it's making this noise, it stops in that speaker. Below is the sound from that speaker after the init sound is gone and this one remains. This is at the 8 sec mark. https://soundcloud.com/digitaldeviant/amp-noise-3 Any advice / help would be appreciated because I have been chasing this down for two weeks now.
Ugh....It's annoying. I have even spoke to car audio guys and they are like bad speakers and bad amp. Some say ground loop or something else, which i have tested. Can my luck be that bad lol. I bought thru amazon and Polk Audio won't warranty it. So I have to return it to amazon. Maybe go with something else after.
