Do I need to override the Bose system?
Hey guys, read a few threads about the whole Bose factory system thing and couldnt find an answer. I have a 2006 g35x, and just installed a double-din HU with an amp and two subs. Of course, Im getting no bass, so what kind of bypass do you have to do to the factory system to make it work?
Ive read things about splicing the wires, unhooking the factory amp/sub, getting an adapter etc. Any help is appreciated!
The amp is only running my two subs.
Im using a harness like this:
Could you describe the complete audio system you're using?
If you went with aftermarket amps for the front speakers, you've got the right harness, you just need to run your own RCAs from the new headunit, run those to your amps in your trunk, then run from the amp to the factory wiring in the trunk that goes up to the front speakers (and from the sub's amp directly to the sub, of course).
If you're planning on using the factory bose amp to drive the front speakers, you've got the wrong part, and you should be using the PAC ROEM-NIS2 instead, as describe in the main DDin install thread - https://g35driver.com/forums/audio-v...urce-list.html
Basically its a double din HU, with rca's to an amp that powers just my subs, all of which are aftermarket. Id like the factory amp to power the factory speakers, so it sounds like I need that PAC item
Would this work though?
Would this work though? Metra 70-7551 Amplifier Integration Harness 995-2005 Nissan and Infiniti: Amazon.ca: Electronics
Because it's an incompatible signal.
This is sticky'd here for good reason:
