G35 coupe Lowering springs
on
i have a 2007 g35 6mt and im looking for springs to get a slight drop .5-1.0 inch so i wont have to really worry about camber and can still go over speed bumps. The thing is i cant find a spring that offers this with good spring rates. i looked at the g35 tein H tech but the spring rates are much lower then stock so wouldnt that mean softer suspension and less performance if anything i would want the same spring rates as stock if not even a lil firmer anyone have any ideas? thanks
https://g35driver.com/forums/brakes-...w-updates.html
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
a while back i was looking for the same type of thing as you and tried the 350z h techs bc i thought the spring rate difference wouldnt be noticeable but i did notice a big decrease in handling with the softer rear springs i also rubbed over big bumps (you may not have that prob if you have a conservative offset) but after trying 2 sets of springs i ended up with coilovers and havnt regretted it for a second just be careful bc some coils have a min drop usually around 1 inch
on
on
Did you look at the link posted above??
350z OEM springs will drop you .5"
RSR G35 coupe progressive springs 1”/1” G35 coupe drop
Spring rates in LBS 315/315
Beware, a 1" drop spring with NO increase in stiffness vs oem.
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher (.8/.7)
Spring rates in LBS 358/375
All of these are under an inch, so you can get away with nothing else
