SPC Rear Camber Arms
Hey guys I ordered a pair of rear camber arms and I was sent the wrong ones. The ones I intended to buy were the 72050's with the bend. But I was sent the 72260's which are straight arms. Is it possible for me to use the straight ones or do I need the 72050s?
I have a 2005 G Coupe
no problem. i have them on my G as well (straight design). The reason the older versions were bent was SPC had some issue where they felt the camber arms would hit the sway bar, or so I heard...But then going back and looking at, they determined this actually was not an issue, thus new straight arm design.
Alright guys, turns out that SPC did change out the design to being the straight arm although, the 72260 is NOT for the G35. I went to the shop today and I found out that they aren't compatible. Those arms for the G37/370Z chassis. So for those of you thinking of swapping them out buy these;
72052.
72052.
Z1Motorsports
Suspension-Vendor
56
05-31-2020 01:56 PM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
