2005 G35 SPC Adjustable Control Arms Ball Joints
Hey guys.. So I have a 2005 Infiniti G35 with SPC adjustable control arms. The place I bought it from did not disclose this (only the struts and springs) so I took advantage of this and they're offering to cover the cost of the work and part to replace the bad ball joint in my front upper control arm. Only problem is, Infiniti doesn't know the part number for these control arms and I don't feel like wasting all of the money they're offering me buying multiple ball joints to get it fixed. Does anyone out there know what SPC adjustable control arms fit the G35 and if the ball joints fit in the different models? I literally just need to find the product number for my SPC adjustable control arms so I can buy a replacement ball joint for around $85 from what I saw online.
Thanks in advance guys and I hope this isn't specifically covered somewhere else. I wish I had more info but this is all Infiniti knew.
Here you go: https://conceptzperformance.com/Cart...on.php?II=7881 Part #: 721204
CZP is a vendor here.
The part number of your SPC arms is most likely Part# 72123 https://conceptzperformance.com/Cart...on.php?II=4358
Yupp! I called that vendor and confirmed from his knowledge it should work too. Already placed my order. Thanks again!
Diode Dynamics
Accessories-Vendor
39
11-30-2021 02:28 PM
quikrotary
2nd Gen (V36) Sedan
11
11-19-2015 05:14 PM
inexorable
17 Inch
09-24-2015 10:43 AM
