Need Help with P0031
on
OP whenever you get codes like this.....there are multiple things it could be. I would check your 02 Sensors and make sure you dont have any frayed wires. Next I have seen people stating a faulty ECU as well. with that being said just start with the 02 Sensors and most likely thats the culprit. Like James has stated above have you installed any mods recently or done anything to the car?? I am in Mckinney and I could take a look at it if you need help as well for a smaller fee than what a shop would charge. 2124-282-2711 is my cell.
on
I have not installed any mods recently but I did get my belts and front brakes changed recently. The only mod that is on the car is the motordyne basic plenum spacer but I installed that like last summer. What I had planned on doing is replacing the heated oxygen sensor on the passenger side and see if that fixes it.
on
on
on
https://g35driver.com/forums/engine-...nger-side.html
Yes its the passenger side. What did you take out to get a breaker bar in there.
on
KhrisG35zone
24
03-24-2014 03:03 PM
