Car is exepriencing U1000 dtc code. Help!
Old 02-27-2011, 11:53 AM
show2nite's Avatar
My G35x 2005, as of lately have been getting the u1000 code it only appears on the OBDII scanner. Nothing shows up on the dash board. The car sometimes is responsive when the accelerator is engage but other times it's not. It feels like the car wants to go but something is holding it back, RPM increases but the speedometer doesn't reflect such.
I have researched this problem extensively :http://engine-codes.com/uploads/ITB06-004a.pdf.
But my car is experiencing a drivability issue, I recently had a remote starter, alarm system and after market radio/navigation unit installed, I am including my most recent developments so everything can be accounted for while attempting to diagnose this DTC code -U1000. Please chime in.....
Old 02-27-2011, 03:28 PM
the_sedan's Avatar
find all of your grounds in the engine bay.....take them loose, clean the surfaces, and snug them back up. you prolly should do it to your cabin grounds that are under the dash too.
Old 02-27-2011, 05:08 PM
show2nite's Avatar
The problem is that I'm unknowledgeable on the whereabouts of the ground points throught out the car, cabin ground / engine bay?
Old 02-27-2011, 05:15 PM
the_sedan's Avatar
umm......there are 2 spots in the battery compartment, a big one under the coolant reservoir and a small one on the strut tower nearby. there are a on the timing cover. and another on the passenger strut tower. i cant remember if there is one in the brake m/c area or not. not around the car to peek. and the big ones inside will be visible once you take off the lower panel under the steering wheel and the glove compartment.
Old 02-27-2011, 06:14 PM
show2nite's Avatar
I had the one located under coolant reservoir and by the strut tower checked also.
What two spots on the battery you're referring too, it is the postive + and negative - terminal area or the fuse box area .....
Old 02-27-2011, 07:19 PM
the_sedan's Avatar
take the battery cover off and you'll see where the 2 spots are. not the battery terminals themselves, but one is the opposite end of the neg cable where it bolts down. dont forget bout the ones on the timing cover too.
Old 02-27-2011, 08:04 PM
show2nite's Avatar
Coupe, thanks for your assistance thus far bro! I'll check them out. I brought a Auto- Multi Meter and ODDII 2 + CAN Scanner. I need to pinpoint this problem it is holding back my car performanc
Attached Thumbnails Car is exepriencing U1000 dtc code. Help!-schematics.png
Old 02-27-2011, 09:21 PM
the_sedan's Avatar
also you can have a 1000 code in different systems, but if you feel a driveability difference....then more likely its in the engine system. just go through every ground you can find first.
Old 02-27-2011, 09:43 PM
show2nite's Avatar
The print out I got back from the Infiniti Dealership displayed U1000, the error was also confirmed later by a tech using a SCANNER, validating the issue with the CAN. But the later print out indicated ABS U1000 error code.
Someone told me to use a Multi-meter to check for continuity & ground.
Old 02-27-2011, 09:58 PM
show2nite's Avatar
Pm'ed you.
Old 02-27-2011, 10:51 PM
the_sedan's Avatar
so you got a u1000 for engine and abs systems. def check grounds. and yeah, you're gonna need a multimeter to check for continuity between wires and for grounds. you're gonna end up pulling the connectors for the ecm and vdc/abs control unit so you can check the pins for any contamination or such, could be a loose connection also.
Old 02-27-2011, 11:57 PM
show2nite's Avatar
Where is vdc/abs control unit located?
dsheldon924 (06-09-2016)
Old 12-17-2011, 11:57 PM
keithk831's Avatar
Bringing this back from the dead. I have the same U1000 code (pulled from the ABS module using Cipher. No DTC on the dash).
I do have an SxExCx grounding kit installed. Can this be related at all?
Old 12-29-2011, 12:00 AM
keithk831's Avatar
Update:
After removing the SxExCx transmission grounding wire, the code has disappeared and hasn't returned in a week. Problem solved!
Old 03-05-2012, 11:19 PM
leanlikeacello's Avatar
my car just got this -_-
Quick Reply: Car is exepriencing U1000 dtc code. Help!
