FS: REV UP partout engine, trans, heads, everything!
REV UP partout engine, crank, block, heads, everything!
I Will take a picture of any item you need all parts are from a 74k mile Rev up car. I removed everything with intent to build a turbo engine and then changed my mind and decided to put a lq9 in the car. I can provide vin number for carfax etc
Transmission CD009 complete with shift tripod, linkage etc mint $SOLD
Crankshaft and block both good 450 UPDATE 400 for all!!
lower engine case half (oil pan) 200
black oil pan cover 25
intake manifolds upper and lower SOLD
center collector 30
Valve cove400rs mint guaranteed NOT leaking $160
Heads complete with cams etc I only have one head now 180 firm
injectors 85 UPDATE 75
timing covers front and back 100
cam covers with sensors the ones the they dont sell separately and cost a ton EACH 140
alternator oem 60
starter oem 55 update 40
headers 25 both
crank pulley 25
REV UP engine harness 175 mint no cuts update 160
sensors??? ask which one
power steering pump 50
water pipes depends on which one or 75 for all
fuel rails 20
if im forgetting anything that the engine includes just ask away.
center collector 30
alternator oem 60
headers 25 both
crank pulley 25
fuel rails 20
