DIY: Pumpkin Swap
DIY: Pumpkin Swap
I recently did another 3.5fd w/vLSD Pumpkin Swap, and i thought id share with you guys how I went about it.
CAUTION: Install at your own risk. This is only a tutorial, and I will not resume responsibilty if anything goes wrong with your install.
First: Raise car and place on jack stands
Remove exhaust mid pipe
Remove bottom rear plastic trim pieces
Remove rear swaybar
Remove rear swaybar
Remove rear bolt
now lower jack by about 2", then push jack forward just enough for the rear stud to slide out. Now reach around top and you will see a rubber hose clamped onto the differential cover. Disconnect that hose [sorry forgot to take picture of this step]. Then you can completely lower the jack and remove the pumpkin.
Install is the Reverse.
TIP for Install: raise pumpkin in place with rear stud in its hole, then install bushing bolts and install till hand tight. Then hand tight the rear bolt. Then torque the bushing bolts. Then torque the rear bolt. Going little by little like this ensures a smooth install because alignment wont give you any hassle.
OEM AT has a 3.3FD gear ratio
OEM MT has a 3.5FD gear ratio
alot of guys that have the AT want to swap their entire differential [pumpkin] with the MT's differential so they can have a higher gear ratio for a relatively cheap price [cheaper compared to getting the aftermarket 3.9 or 4.083 gears installed into the pumpkin itself]. The higher final drive gear ratio shifts the power band over, and gives you torque earlier on in the each gear.
Torque specs = the amount of torque each individual nut or bolt have. In other words, how tight the bolt or nut should be. The amount of torque turned on a nut or bolt can be determined by using a Torque Wrench.
FYI: Torque Specs are determined by the NISSAN engineers
What can I say? I may go out of my way and spend an extra 10 min to get somethings out of my way to make life easier and prevent scratches on customer's exhaust pipes and sway bars. Unlike some people, I like to work smart, not hard. And i always torque nuts and bolts to specs. Some people drive like a grandpa and never put any real stress on their cars, thus getting away with not having to torquing to specs. But i deal with all types of drivers and i like to do things right the first time. But hey, what do i know? Ive only installed a dozen of these without any customer complaints.
Dr.Fate (09-07-2013)
ill Sedan
