Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Momentum Performance Single Turbo Kit... Sales and Installation @ Z1 Motorsports
Old 06-17-2011, 09:09 PM
Z1Motorsports's Avatar
Momentum Performance Products!
Although Momentum Performance no longer exists, Z1 Motorsports has several of these items in stock & ready to ship.
Momentum Performance 350Z / G35 Cat Delete Y-Pipe
The Momentum Performance 350Z / G35 Cat Delete Y-Pipe was designed for someone wanting all out performance and the ultimate airflow. Since this Y-Pipe has integrated test pipes which removes the catalytic converters it is intended for off road use only.
By deleting the factory catalytic converters and replacing them with the Momentum Performance 350Z / G35 Y-Pipe not only are the multiple welds and seams of the factory exhaust system eliminated but important weight savings over stock are also introduced. The Momentum Y-Pipe’s integrated test pipes offer a shallower angle than other products, and are manufactured out of TIG welded, mandrel bent 304 stainless steel for the ultimate in strength and corrosion protection. The 350Z / G35 Y-Pipe reduces exhaust heat, flow matches exhaust gases for more power production and improves engine breathing.
This Cat Delete Y-Pipe also offers added convenience when servicing the transmission / changing the clutch by allowing you to leave the exhaust in place completely. Manual transmissions can be removed through the opening of the Y-Pipe meaning (for routine maintenance) you never need to remove the Y-Pipe once it is installed.
Order Here!
Momentum Performance 350Z / G35 Solid Transmission Mount
For the driver who wants to capture as much engine power as possible, the Momentum Performance Solid Transmission Mount takes out all of the slop and lets you put the power to the ground.
If you spend a lot of time on the track and value responsive suspension tuning, you will appreciate the tactile feedback you get with a stiffer platform.
The mount is machined from 6061 aluminum, with 304 stainless inserts and installs with the factory hardware.
Order Here!
Momentum Performance Single Turbo Kit 350Z / G35
The Momentum Performance turbo kit is an amalgamation of the finest components in the market plus their own proprietary tubing and tune that delivers a corvette stomping 350Z / G35 to the end user. This turbo kit has been field tested with real data for over five years and 100,000 miles. You can be ensured that the power, durability, and drivability are the best they can be. Momentum's manufacturing process promises consistent and predictable installation times and efforts by ensuring each individual piece meets their strict standards.
2014 Update : Z1 Motorsports has Momentum Single Turbo Kits available, however in house installation and tuning is required.
Please call us for details and to set up your appointment.
Old 06-24-2011, 11:47 PM
(Stealth Inc.)'s Avatar
this sounds like a great deal, do you have a lay away program? LOL!!
Old 06-25-2011, 12:04 AM
DrewDrew's Avatar
if I ever go FI, this would be the kit I get. hands down. the reviews and vids are amazing.
but...is it possible to run a true dual exhaust with the kit at all? or is there a lot of custom piping/fabs that you'll have to do?
Old 06-27-2011, 12:26 AM
We have the Momentum Dual Exhaust on the G and we're very pleased with the performance and sound.
Old 06-27-2011, 10:15 AM
damafuka's Avatar
Sick price...how much with install?
Old 06-28-2011, 03:43 PM
B T's Avatar
B T
B T is offline
any fitment issues with a sedan that your aware of?
Old 06-28-2011, 03:50 PM
da mayor's Avatar
Vinny Ten Racing did my install on my sedan... just a few modifications on a few pipes...
the Momentum kit is a real clean kit as far as quality and parts go!
B T (06-28-2011)
Old 07-07-2011, 06:57 PM
Give our service department a call and we'll be glad to give you a quote.
Old 07-13-2011, 04:01 PM
This kit is by far the best Single Turbo kit available for your G or Z.
Old 07-25-2011, 05:56 PM
Give us a call today for a custom quote.
Old 07-27-2011, 04:08 PM
Give us a call today!
Old 08-04-2011, 07:22 PM
Give us a call today for the absolute best pricing on these kits!
Old 08-24-2011, 10:24 PM
In stock, ready to ship.
Old 10-05-2011, 11:41 AM
Give us a call today for best pricing.
Old 10-14-2011, 09:37 AM
In Stock! Ready to Ship!
PM me for Special Pricing!
Quick Reply: Momentum Performance Single Turbo Kit... Sales and Installation @ Z1 Motorsports
