Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
The Original ZSpeed Performance Aluminum Engine Splash Shields!
Old 03-06-2013, 05:27 PM
ZSpeedPerformance's Avatar
ZSpeed Performance Aluminum Under Shrouds
Save Some Green Sale!
Enter "10OFFZSPEED" at checkout and Save 10% (or more) this month only on all ZSpeed Performance Splash Shields!
Designed Correctly and as always, PERFECT FITMENT! You won't need to drill out holes to make our parts fit!
In Stock and Ready to Ship!
Click here to purchase securely on our website
All of these Zspeed Performance aluminum shields have been road and track tested, Fit perfect and are properly designed. These are laser cut and professionally produced to perfection!
These under shrouds were developed by Zspeed Performance to protect your critical engine parts under the car and also because the cheesy plastic OEM shield deteriorates over time and usually ends up on the highway behind you somewhere.
Without the shield in place the air that comes in through your fascia should be directed into you radiator and instead will just take the path of least resistance and exit under the car instead of cooling off your radiator. Just like the upper radiator air guides keep air going through the radiator, The bottom is even more important to have in place as it is much easier for air to escape there.
The under shrouds will fit These fit 03-07 G35 coupe/ 2002-2006 Sedans (RWD Only) 2003-2009 350Z's with stock front fascias and should fit any fascia that the OEM under shroud still bolts to. These have only been test fitted on stock bumpers.
Will not fit G35X All wheel drive sedans
The ZSpeed under shroud will help give the lower front fascia much more rigidity also, As you probably know, running without the shield in place at high speeds can do serious damage to the front fascia as it will droop down and can rip apart.
The BEST feature of all though is that you can actually change your oil AND filter without removing the entire shroud. I have integrated a oil change access door into the shroud so all you have to do is remove 2 bolts and you have ample room to get to the oil filter and drain plug even with the GTSpec V-1 front tie bar in place. Have not test fit with the V2 tiebar but it doesn't look like it will work with it.
Very lightweight and much more protection!
Powder Coated, Matte Black
These are available in non-powedercoated aluminum at a lower cost
Fitment
2003-2008 350Z
2003-2007 G35 Coupe
2003-2006 G35 Rear drive sedans.
This will clear the deeper aluminum oil pans on the G or Z and also fits with the JWT oil pan spacer and stock pan.
If you have an aftermarket aluminum oil pan that goes under the oil filter you may not be able to get to the filter without removing the shield.
Works with Vortech supercharger kit, Some slight pipe adjustments may be needed.
Known to fit with the Nismo V2, Charge Speed and a few others, If your stock shield can still be attached to your aftermarket front bumper this will also.
Click Here to purchase securely on our website!
Old 04-07-2013, 11:28 AM
Bump! Coming Soon!
Old 05-26-2013, 11:31 AM
Bump!
Old 05-29-2013, 11:56 AM
Bump!
Old 06-07-2013, 02:31 PM
Bump!
Old 06-14-2013, 08:22 AM
Bump!
Old 06-19-2013, 02:46 PM
Bump! Plenty in stock! Normally Ships SAME DAY!!
Old 06-26-2013, 03:57 PM
hUmP DaY BumP!
Old 08-18-2013, 01:05 PM
Bump!
Old 09-24-2013, 12:37 AM
Bump! In Stock, Ships Same Day!
Old 01-28-2014, 04:09 PM
Bump!
Old 06-19-2014, 09:27 AM
In Stock! Ships Today!
Old 06-20-2014, 01:50 PM
Why Buy the Original? The Best, The one that started it all?
Best Fitment
Best Materials
Includes Hardware
Ships Fast
Original Designers
Best Customer Service
We are an ACTUAL Brick And Mortar store, Not a fly by night out of our garage company copying others.
If you smash a Zspeed Shield we will replace it at a greatly discounted price! Just send your old one back and have your new one in no time!
Old 10-16-2014, 01:49 PM
Bump!
Old 12-08-2014, 02:22 PM
Bump! In Stock!
Quick Reply: The Original ZSpeed Performance Aluminum Engine Splash Shields!
