DIY single turbo build write up
#167
#168
#169
Orlando spy report.
A little something to keep everyone occupied while we wait for the dynograph.
On the dyno.
Quick little pull during the tuning phase.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://img.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v469/f8l_0e/DSCF2127.flv">
And finally a road test.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://img.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v469/f8l_0e/DSCF2132.flv">
On the dyno.
#173
ok guys...
here is the run down on the car. i like the idea/design of the kit. the 2.5 inch crossover and u pipe work perfectly. the 3 inch downpipe is nice too. for a one off kit , i would say that its a pretty good job. the welds definitely need some improving and there are a couple small exhaust leaks. the downpipe hits the fenderwell inside which causes some vibration but i know how tight that fit is.
the ebay parts i am not a fan of. BUT, they are working fine for now. i would like to say that the kit made VERY good power for the given boost levels. 6 psi made numbers higher than the TN ST on 8 psi does.
good job on the DIY small budget turbo kit though!!
the clutch in his car is DONE. as soon as he can get back up here , we will be throwing in a clutch and retuning it on 8-9 psi and this kit should easily make over 400 whp..
thanks guys!!!
thanks guys!!!
#175
#177
Originally Posted by Dsskyline
man that dump is loud!!
I like it and it sounds like the other PF ST cars to me for some reason.
With what you said, Jeremy, I bet I'll be embarrassed when the numbers are posted But one thing I'm for sure of...his clutch doesn't slip as bad as mine did
#180
