Is my milage too high for a turbo/supercharger?
Any consumption issues? Are you an AT or one of the rare 6MT sedans? The difference would be in the Rev up or Non-revup.
AT is also good and bad. Good because it keeps your goals reasonable- bad because if you plan up upgrading it, it can cost a small fortune.
MT is less expensive and allows for "better" power management- but can quickly result in getting in too deep because you keep wanting (and getting) MOAR!
You'd want to do a leak down test to help verify if the block is "tight" enough for boost- even low amounts. Reasonable gains can be achieved for reasonable costs... depending on what upgrades you've already performed to the car. However a blown motor is a blown motor- whatever your intention- to have to go through the expense of replacing an engine for a meagre 150hp or so... suddenly you end up spending 10-15k and you still have a car with 105k + miles on it.
How many miles do you put on a year? (if 15K+ might as well wait for the engine to blow)
Are you the first owner or do you know how the first owner took care of the engine? (this is important for longevity)
Have you had to add oil between normal changes?
If there is nothing scary about the above info, then I'd then get a compression and leak down test done and shoot for modest goals (375-400 whp)
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
