car wont turn on now
Old 02-05-2015, 03:33 AM
henrylopes's Avatar
06 g35 coupe with 97000 no mods..car been sitting for 3 months now i recently changed the battery and car cranks but does not start (like if the alarm is on) trowing codes /p1610 -p1614 i only got one key for the car anyone could help greatly appreciate guys
Old 02-05-2015, 09:16 AM
DroidDonACR's Avatar
Could be a broken keyfob or something with the ECU. Do you have the intelligent key?
Old 02-05-2015, 02:48 PM
henrylopes's Avatar
YEa i got the original key ..n the key unlocks door lock doors up ..and even cranks the car just wont turn on
Old 02-05-2015, 03:05 PM
Ejgold55's Avatar
Old 02-05-2015, 05:55 PM
henrylopes's Avatar
nee update
Had a locksmith come out to reprogram the key ..key is programmed to the car ..and still does not turn on
Old 02-05-2015, 06:39 PM
wuzz-upp's Avatar
I would try to determine if it is an ignition or fuel problem first, that way you can focus on the right system. I would spray some engine start fluid into the air intake filter and try to see if it will want to start. If it fires up, you have a fuel supply problem, if not then it is an ignition problem. Try to isolate the problem to one of the two systems. Don't over do it with the engine start fluid, but put enough for a start.
Old 02-05-2015, 11:20 PM
henrylopes's Avatar
I did try that no success. They say something about this code cutting of the injectors
Old 02-14-2015, 10:53 PM
henrylopes's Avatar
[B]Update[****/B] finally got the car turn on by DISaBLing the nats codes (p1610-p1614) thanks to RT TUNNING ........
Old 02-18-2015, 03:01 AM
partyman66's Avatar
Curious exactly how you did that? PM maybe so people don't search on the answer and use it to steal our cars.
Old 07-09-2019, 11:33 PM
Kingdeasy24's Avatar
G 35 coupe
2004 g35 coupe
Hello , My g35 is acting up , it always starts but now it’s not. I drove to work when in and when I come out to start the car it wouldn’t start. It’s just making a beeping sound . The alarm is just beeping when I put the key in to try and start it. The code that is popping up is p1614. Can you help ? I need this car back on the rode asap
Old 07-10-2019, 02:16 AM
Scorpi0's Avatar
Read this..... It might help:
https://www.nissanclub.com/threads/n...-p1614.314526/
Hasanbaloch
02-29-2024 08:45 PM
Mry
03-03-2023 01:03 AM
chinee
04-19-2021 09:18 PM
ddietz97
07-26-2015 06:16 PM
G35OUTLAW6MT
07-13-2015 02:26 PM
Quick Reply: car wont turn on now
