Brakes dragging
Brakes dragging
I just completed changing the rear brake pads and rotors on my 2006 G35. I got everything back assembled but before I put the wheels back on I noticed that the pads are contacting the rotors on both side.
Seems like the calliper isn't releasing. I did clean and lubricate all the calliper slide bolts and all the other components. I compressed the brake pads using a c-clamp and an old brake pad and the calliper pistons when back in just fine. Flushed both rear brakes of fluid (which was already quite clean). Is there any way to free a stuck calliper piston or am I looking at needing to replace the calipers?
I changed the parking brake shoes because they were worn out. I haven't adjust the parking brake yet because it is hard to tell with the pads rubbing
You can adjust the parking brake system with the rear calipers removed, Just make sure you don't depress the normal brake system pedal with the calipers removed. Is your vehicle stick or automatic?
They looked alright but I will check them again. It seems strange that the calipers would be seized as the pads were worn down evenly on both sides and there was no pulling to one side when braking. Good working the pistons back and forth with the pads removed help to free the piston up?
Yeah you just have to rotate the star wheel to the right to tighten if I am not mistaken. Hard to know how much drag from the parking brake shoes when the pads are contacting the rotor.
For me the adjustment was not that tough, turning the star clockwise or down, expands the brake shoes towards the braking motion.
Okay I extended and rotated the pistons back in a few times so I could hopefully work them free. I put the wheels back on and lightly accelerated with the wheels off the ground. The pads are still dragging and you can visibly hear them as the wheels rotated. Looks like I am in for new calipers.
I can get a new/rebuilt set of Raybestos callipers for around $60 a piece. I don't have any experience with Raybestos but would these be sufficient?
Alright so I changed both rear calipers with the Raybestos replacements but the brakes are still dragging. I double checked all my work and everything looks good. This is becoming a real frustration. When I tried to accelerate to listen to the brakes the VDC kept kicking in. Only way I could spin the wheels was with the VDC off. I guess I could have a bad master cylinder or brake line but I don't want to replace things I don't need to.
