Need Some Help with VDC/SLIP Lights
Old 09-22-2015, 03:27 PM
MThawkins86's Avatar
I have googled, binged, and Yahooed...but I don't see anyone with the same issue as me.
2004 G35 Coupe
Automatic Transmission
93500 miles
My VDC/SLIP lights come on as soon as I start the car. I have no codes on my ecu. I have topped off the brake fluid, I have brand new brake pads and rotors on the car. I have had my alignment checked out and I am good to go. I am not sure what else it can be. Everyone with the VDC error seem too come on after driving but mine pops up as soon as I turn the key.
I have disconnected the battery and let the car set for 12 hours to try and reset everything but still I have the solid steady VDC/SLIP lights on. I have changed the both cam sensors and the cranks sensor.
Any advice would be greatly appreciated.....
Old 09-23-2015, 02:58 PM
Void's Avatar
I don't know much about your situation but maybe the traction control fuse is blown or bad.
MThawkins86 (09-23-2015)
Old 09-23-2015, 03:14 PM
Jusseth's Avatar
Check your speed/abs sensors.
Old 09-28-2015, 05:30 PM
vq35dedriver's Avatar
I had this same issue and it was cause my brake fluid was low.... check fluids, worth a try
Old 09-28-2015, 06:09 PM
I checked all the fluids I have topped off brake fluid. The lights are soild on start up and never go out still.
Old 09-29-2015, 10:10 AM
Jusseth's Avatar
Have you checked the Speed sensors? Maybe they are dirty?
MThawkins86 (09-29-2015)
Old 09-29-2015, 03:42 PM
I am going to take off all 4 wheels today and clean all the sensors just to be safe.
Old 09-29-2015, 07:22 PM
Mignav01's Avatar
I can almost guarantee its the sensors. In the same situation here, getting my right rear one replaced
Old 09-29-2015, 07:47 PM
Lartytiejdke3's Avatar
I would love to know how you guys are replacing/cleaning these suckers. Mine are tripping the lights as well
Old 09-29-2015, 07:48 PM
Mignav01's Avatar
Well I'm still looking on how to clean them as well. But if it doesn't work looks like I'll be buying a new one
Old 10-02-2015, 12:02 PM
I ordered all the sensors and I waiting for them to be delivered
Old 10-02-2015, 12:08 PM
Mignav01's Avatar
How much were the ABS sensors? I was quoted 250-400$ a piece
Old 10-02-2015, 03:36 PM
Jusseth's Avatar
I will be posting a DIY with pictures maybe this weekend.
FYI, there are only front speed sensors.
Steps:
1. Remove wheel
2. The sensors are located in the inner side of the caliper (towards the mud guard), follow the cable that comes from the engine bay to the rotor
3. remove the 12mm (or 14mm-not sure) bolt that holds the sensor in place
4. once removed, clean the sensor housing
**This will be a good time to check the sensor cable for any cuts/scrapes or any damage to the actual sensor**
5. For you that have not replaced/removed rotors, you need to clean the area that the sensor is using to send the speed signal to the computer. You may use a cloth/rag to clean the area by spinning the rotor and sticking the rag in the sensor's place hole (I will be posting pics later).
6. Once everything has been cleaned, replace the sensor back into its place and put your wheel back on.
Lartytiejdke3 (10-02-2015)
Old 10-02-2015, 04:29 PM
Steps:
1. Remove wheel
Heavenly blessed beauty. Thank you for your efforts. Looking forward to the pics
Old 10-03-2015, 02:54 AM
So what are the sensors in the rear than? They are not bolt to the back of the hub. they are on each side of the rear differential. The come up as rear ABS speed sensors
Quick Reply: Need Some Help with VDC/SLIP Lights
