Trouble shifting into some gears.
on
1 Post
G35 coupe 6MT Brembo Premium
(6-speed MT) On occasion, ONLY after driving for 20+ minutes, it becomes more and more difficult to shift gears, particularly Reverse and going into 1st from neutral. I have to re-pump the clutch twice, sometimes more until it becomes unstuck, while almost forcing the shifter. It is usually followed by a loud noise from beneath the car (transmission?) when the gear is finally shifted.. Other than that, my car runs well and fine 75% of the time.
This also never happens from a cold start. Also, the problem goes away once my car has been off for at least an hour.
What could be the issue here? Clutch going bad? Synchros? Tranny fluid? Clutch / Differential fluid? or worst case scenario... transmission going bad? Something else?
This is stressing me out.
I just bought this car used a few days ago and the previous owner did warn me about it, but he was clueless as to what causes it. Also, it has a short-throw shifter if that helps.
Easy to tell if it is the clutch which is my guess (no a worn clutch will not do this but another issue will). Does the problem persist if the car is NOT running? If so, sounds like either a clutch pressure plate issue or a release mechanism issue. Aftermarket clutch? How many miles? Could be what just happened to me... Pressure plate bolts came loose.
JM Auto Racing
Cars For Sale-Vendor
02-03-2018 11:35 PM
