Cooling fans problem HELP!!
Hello Im new to this page but i have a problem with my 2003 g35 coupe about 4 weeks ago it started to over heat got a new thermostat installed it myself but than when i tired to take it home it started to over heat again so once i got home i left the car sit for a whole day and when i started the car back up it didn't overheat again but now my cooling fan wont stop spinning and they told me it was the temperature sensor so i went and got a new sensor but they still wont stop spinning. what do i need to do now car runs and drives fine but the fan just will not stop
on
http://www.nicoclub.com/FSM/G35/Coupe/2003/co.pdf
See page CO-24
"7.Remove thermostat and thermostat housing.
Do not disassemble thermostat and thermostat housing.
Replace them as a unit, if necessary."
With a fourteen year old vehicle I not only would replace the thermostat and housing as well as the water pump, radiator cap, hoses and coolant.
Use factory OEM parts.
Do a pressure test
Telcoman
edwinisdumb15
SOCAL Meetings & Events
09-02-2016 03:31 PM
Jiggs1219
02-25-2016 08:30 AM
