cigarette lighter not working
So I was using one of those power inverter things you can connect laptops into then it stops working.
I tried other stuff and the cigarette lighter isnt working.
I checked the fuse box near the clutch where the labeled cigarette lighter fuse is located and its NOT blown.
What else could be wrong?
Another fuse? Blown wire?
Car is a 2007 G35s 6MT...still under warranty so I could just take it to the stealer but its an hour away and its an easy fix i'd prefer to do it.
thanks all
thanks all
Are you sure it's not working? Some of these plugs are funky and don't make contact properly...
But if you're sure, it's probably the contact in the back loose... but for that you'd have to remove the shifter trim to get to it. It's not hard, but if you're not comfortable with it I'd just give it to the dealer.
2008 g35 where is fuse located
HELLO i purchased some cheap electronic n now suddenly i cnt charge nomore in the cigarette lighter outlet..i want to make sure im checking the right fuse box!! Is it by the driver side door or by the battery...please help ..thanks..i bought new fuses and still dont work..also im missing a cigarette lighter cover..
