Do I need a new ballest or a new bulb
Posted here as I thought would receive the most exposure. Anyhow last night I got a ticket for a burned headlight which I was aware of. Here's the thing though the dumb light turns on for like 30 secs then turns off? A quick google determined that I need a new ballest as anyone ever had an issue with this?
I had this issue before and I thought it was the ballast burning out.
However, I changed out the bulb to a new one and it has been fine. The only real way to check is to change out the bulbs since they're the cheapest of the two first. If the new bulbs don't work, then change the ballast.
It is much less work to change out the bulb than the ballast, so I would start with the bulb.
We'll see how they work. Also while we're on the subject of headlights, what's the easiest way to clean them. can I really use toothpaste ?
Really they should be replaced ever couple of years if you do moderate amount of night time driving, definatly not life of the car. I guess if you hardly ever drive at night, they could last life of the car.
Here is a typical Philips loss curve
He is right, most common failure is ballast.
I ordered these from amazon
Amazon.com: MAXLUX HID Xenon Bulbs D2C (D2S/D2R) 5000K (1 Pair, Pure Star White): Automotive
That's a sign of bulb about to go out. I've seen it quite often where the bulb outputs a pinkish hue. Usually, the BALLASTS last the lifetime of the car, and the bulbs go out. Ballasts don't usually go bad. Our headlights are sealed so water entering the ballast is rare unless it isn't attached properly to the headlight housing. There's a rubber gasket that prevents water from entering the ballast.
Just because a bulb is rated for a certain lifespan doesn't mean it'll go out by that time. It is usually the average lifespan. Some humans live much longer than the expected lifespan, and vice versa.
This is an example of a bulb on its way out while the ballast is still functioning properly:
I would either stay with Philips D2S bulbs or Osram D2S, as they are OEM suppliers for most car manufacturers for HID bulbs. Our cars came with Koito bulbs, so that is also a viable option. Our ballasts are Matsush-ita. Remove the dash.
Has nobody ever seen the "pinkeye" in cars that have HID headlights? It was popular in older Acuras and older BMWs with HID.
