Raceland Coilover Problem
Drifter2090 (04-10-2015)
do you have to pull out the springs for the full body coilovers because when i got them installed they are still in place i think that is why they arnt going lower
don't listen to that guy, he's throwing the "gotta pay to play" card after buying an 04 high mileage car....ok guy
Here's the best advice your going to get on here about technical questions, ie. suspension, drivetrain, etc.:
Don't ask them here and certainly not in the general media share section, you will get worthless and often hugely erroneous advice, go to my350z.com instead
In your particular case, go to my350z.com, then the suspension section, make a new thread, and include pictures with specifics on what you are trying to do and what's not working.
good luck and have fun
Here's a couple pieces of advice.
1) learn to work on your own car. You're 17. Learn it now before you have like a real life to take away from car time. coilover installation is one of the easiest mods to do (albeit time consuming) because you're literally just removing a part and putting a part back in it's place. But, that goes for everything. Our cars are fairly straightforward.
2) NEVER EVER EVER EVER ask TECH questions on this forum. This is how it always goes.
-Hey. I have a thing broken on my car. How do I fix that thing?
-Have you bought the most expensive version of that thing? No? Do that. Then it'll fix itself.
-Hey. My car is broken. How do I fix it?
-buy a 335i
LITERALLY every technical discussion on here for the last 4 years. lol
3) If you're hearing a grinding when driving but it goes away when you apply the brakes, it's PROBABLY your pads and rotors. You can actually stick your hand onto the rotor (after they've cooled down) and feel it. If it's feels like there's ridges or it's grooved, change them. If it feels extremely smoove, then you should remove the wheel and check pad depth (unless you have a guage that you can do that through the wheel. They're about $.83 cents at Autozone).
Hope that helps.
-buy a 335i
Hope that helps.
And he is gone.... 1 questions and PEACE OUT.....If the mechanic really installed the stock springs.. NEVER EVER EVER got back to him... That is a absolute moronic thing. Thats like not tightening the lug nuts or putting oil BACK into the car..... Anywho. Glad you figured it out! On a side not I would personally ditch those coils. I have seen MANY of then snapped... Springs popped... As a 17 year old You can figure out a lot on this car!!!! Its really a very easy car to work on! Coils are 6 bolts up front and 6 in the back per side. I can have a set done in 3 hours. But I am 27 and have been working on cars since I was 14..... I have done multiple coils on cars and the 350/g35 i one of the easiest! Hardest was my Speed3 or my VW's... Or my Audi those are a pain... You can do a lot of the things yourself! Heck instead of buying 3-500 dollar sets of coils you could have bought an 800 dollar set and installed them yourself!
I figured out the problem, when I got them installed the mechanic didn't take off the stock springs so it was just sitting on them and not lowering after I took them out it rides 10x better and its lowered but, my brakes started to make a weird noise only when rolling but after I would apply them it would go away. It's more of a grinding sound then a high pitched noise
if the noise goes away sounds like it might be the brake shield rubbing. i think i had that same issue right after i got mine lowered...
Freeman186
09-06-2023 10:07 AM
