F/S: KP Technologies Window Roll-Up & Traction Control (VDC) Modules
Old Dec 14, 2006 | 07:41 PM
sin4me's Avatar
Selling both brand new for $85 shipped. First come first served. $100 on their website + shipping.
http://www.kptechnologies.net/
Old Dec 14, 2006 | 11:48 PM
hipvspec's Avatar
do these void warranty?
Old Dec 15, 2006 | 02:10 AM
mephistomyhero's Avatar
If you have a bad window motor or your car goes limp, you betcha they will give you hell at the stealership. However, if your MAF goes bad, you'll be fine.
Old Dec 15, 2006 | 11:34 AM
Calvin's Avatar
Overglorified Altima
willing to part out the window up module? if so, how much shipped to 91741?
Old Dec 16, 2006 | 09:35 AM
MardiGrasMax's Avatar
I'll take the VDC if you part?
Old Dec 23, 2006 | 08:42 PM
safil's Avatar
I'll take both of them if you still have them. Hit me up with a pm. Thanks!
Old Dec 27, 2006 | 08:24 AM
KPierson's Avatar
The modules will only void your warranty on the part of the car the module is attached to.
This means, that if you lose the ability to raise the windows through your drivers side key cylinder Infiniti might not fix it for free. Please keep in mind that this module hooks in to the factory BCM. NOT the power window system. There are NO high current outputs on this module, everything is low current, signal level connections. The module works by sending a signal to the BCM to request that the windows be raised. If the BCM approves the request IT raises the windows using all stock relays/controls. The KPtech module does NOT directly drive the windows. In 3 years we've never been notified of a denied window motor/regulator issue on any Nissan/Infiniti vehicle because of the addition of this module. If someone does run in to this situation KPtechnologies is willing and capable of talking directly with your service department to explain why this module does not effect the operation of the power window system. Finally, all inputs/outputs are current limited and we've never had a single report of any damage to ANY car that has resulted from the installation/use of any KPtech product.
As far as the traction control module it ties in to the VDC/ABS computer on the same line as the 'VDC Off' switch. So, if for some reason your switch quit working they might void your warranty, but again, to date, that has never happened.
Any other questiosn let me know, I personally designed and coded both of these modules so I know a thing or two about them.
Old Jan 1, 2007 | 04:49 PM
in2win's Avatar
install
can you include pics of an install? or a link, wondering how involved it is besides removing the door panel. thanks
Old Jan 1, 2007 | 10:47 PM
KPierson's Avatar
Old Mar 15, 2007 | 08:45 PM
sin4me's Avatar
Have been out of the country due to unforseen circumstances, but am back stateside. These are still available, both are still brand and in original packaging.
The price has been reduced to $70 for both, which includes shipping costs. Please PM me if you are interested. Thanks!
Old Mar 16, 2007 | 04:03 PM
havocwreaker's Avatar
pm sent
Old Mar 16, 2007 | 04:45 PM
sin4me's Avatar
sale pending
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
philthethrilloh
Sep 9, 2015 01:25 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
