FS: Ksport Pro Coilovers G35/350z
Old 11-13-2008, 09:35 AM
NorthSideRacing's Avatar
Arrow FS: Ksport Pro Coilovers G35/350z
Product description
Kontrol Pro Damper System
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Feaures:
1.36 levels of adjustable dampening
2.Made from high quality 6061 aluminum with T6 for increased hardness
3.Compression/Rebound adjustable
4.Adjustable spring perch for height adjustment
5.Adjustable body allowing maximum suspension travel
6.Monotube high pressure design reduces oil leakage
7.Electroplated body for protection from corrosion and rust
Here is a sample picture of the coilovers. Since they are still on my car
There are no leaks nor are they blown. The ride is like i first put them on excellent. rides feel like stock, just alittle stiff since i adjusted the damping
I have the orignal box, with the wrenches, and damping key.
Asking $790.00 shipped/paypal fee
Old 11-13-2008, 02:49 PM
patman530's Avatar
how many miles do you have on it?
Old 11-13-2008, 03:36 PM
i could really tell you to be honest. Give or take 10,000 miles or less.
Old 03-27-2009, 05:38 PM
Need these gone!
Old 03-29-2009, 09:01 PM
MrOREO's Avatar
are these front and rear?
Old 03-30-2009, 10:17 AM
2- Fronts
2-Rear
2-Wrenches
4-Adjustments tools for damping
Original Ksport box
Old 03-30-2009, 12:53 PM
uprockd's Avatar
is this the tru coilovers? and wats the sprig rate?
Old 04-05-2009, 03:40 AM
PM sent
Old 04-16-2009, 09:12 PM
Please! Np low ballin or whats the lowest crap.
Old 04-16-2009, 10:23 PM
g35brandon's Avatar
good price...wish I had the cash now lol
Old 04-16-2009, 11:57 PM
jouvert00's Avatar
pm sent
Old 04-17-2009, 09:35 AM
waijai's Avatar
i.love.gold
So what's next?
Old 04-17-2009, 07:47 PM
Originally Posted by waijai
So what's next?
Your suspension
Thanks! Its a fair price.
Just tell that to the people that low ball me
Old 04-18-2009, 11:40 AM
SMEEwee's Avatar
trade you a bottle of patron eddie..hahaha
Old 04-18-2009, 05:22 PM
LOL
Quick Reply: FS: Ksport Pro Coilovers G35/350z
