Need Help With V1 Radar Detector Power Supply
Old May 22, 2006 | 03:15 PM
MikeyMike's Avatar
Rollin On Dubz
I got a Valentine V1, but the cord that connects from the V1 to the cig lighter doesn't work.
Can I use any type of cord, or does it have to be a particular kind for the v1? Also, where can I buy it from? Any radio shack?
Thanks guys
Old May 22, 2006 | 03:25 PM
Espresso's Avatar
Check the fuse in the V1 cig adapter plug.
Old May 22, 2006 | 06:54 PM
dukieman23's Avatar
yeah check the fuse, it should work...i have a v1 too and i plug it there. make sure the car charger is lined up in the correct orientation although it shouldnt matter. I moved it around a few tiems before i got it to work once.
Old May 22, 2006 | 06:59 PM
MikeyMike's Avatar
Rollin On Dubz
What if I don't have the power cord? Is there one I can buy from radio shack?
Old May 22, 2006 | 07:38 PM
optimystic06's Avatar
Yeah; they have power cords you can use or you can use something like this: www.invisicord.com for a stealth install
Old May 22, 2006 | 07:44 PM
MikeyMike's Avatar
Rollin On Dubz
Can you still use that if your car's rearview mirror doesn't have the power supply? (no premium package)
Old May 22, 2006 | 08:02 PM
Yes; basically the installer will run it through the headliner; down the a-pillar; and tap into the fuse box. That is what mine did when he installed my homelink rearview mirror on my base coupe.
Old May 22, 2006 | 09:50 PM
dovla's Avatar
OK for wires, but what about that clip holder (Radar Detector Mount)? Does it fit same as with homelink mirror? Thanks
Old May 22, 2006 | 09:55 PM
SILVRG35's Avatar
I hardwired mine to the fusebox this weekend. Looks much clean than a dangling cord.
suby01
Not G35 Related
May 25, 2016 03:07 PM
vamarris
Sep 26, 2015 12:56 PM
