DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 6 votes, 4.83 average.
  #496
Old 03-29-2011, 07:46 AM
donthaveityet's Avatar
here is a picture of my amp. sorry if my crappy description wasnt understandable it was late lol... iknow that each speaker has a (+) and a (-) my question is do i need 4 rca plugs or will i just use 2 and plug them into the input side of the amp.
Attached Thumbnails DIY:  Add a sub to your Bose equipped G35 Coupe-imag0124.jpg   DIY:  Add a sub to your Bose equipped G35 Coupe-imag0125.jpg
  #497
Old 03-29-2011, 04:23 PM
nissandrifter32's Avatar
Looks great when it looks like it came with the car...I'ma have to look into doing something like that
  #498
Old 04-01-2011, 04:01 PM
eurodre's Avatar
question for you guys, for the box if I don't want the 4080 did you guys use just a regular generic box or what? if so did it fit in the trunk there?
  #499
Old 04-03-2011, 09:38 PM
justin_2009's Avatar
I have a question for the people that know a bit about car audio and more specifically these g35's. I have a 2005 G35 coupe with Bose. I am hooking up subs real soon and this thread is going to help me a lot! but i made a box that has two 12's and a pair of 4x6's. I love the box i made and had it in my previous 2004 G35 coupe, but that one had an after market Kenwood DNX8120 so i was set. Now i just ordered a new Kenwood KAC-9105D amp and plan on hooking that up to my 12's but for my 4x6's I have a older pioneer 200w max amp that worked good in my last set up but last time i used the "high level input" and tapped into my rear speakers but the new kenwood amp I am buying has the pre-amp output. So my question is can i hook up my kenwood amp and then run some RCA cables to my small pioneer amp to run my highs or does the headunit only send lower frequencies to the 6x9's and will cause my 4x6's to try to put out lows. I am pretty good with car audio and could figure this out when all my stuff comes in but if someone could tell me first so that i know if i have to run more wires that would be great. THANKS!!
  #500
Old 04-04-2011, 01:41 PM
jake227's Avatar
OK, first of all, why do you have 4x6 speakers in your trunk? Do you park your car, stand behind it and listen to music with your trunk open? If so, then fine but for just driving around those speakers are worthless in your trunk.....ditch 'em.
To answer your question - you can run RCA cables from 1 amp to the next. However, I'm pretty sure the signal going FROM the bose amp TO the 6x9's in the trunk is not a full-range signal, its only for lows. To get a full-range signal, you need to tap into the signal going from the headunit to the amp. This is the best way as the bose amp EQ's the crap out of the signal. Also, by doing it this way you will need make sure that your amp can accept a balanced-differential signal. If it cannot, then you will need to get an L.O.C. that can convert the signal to standard single-ended.
  #501
Old 04-04-2011, 05:55 PM
yes, the 4x6's are just for car shows and showing off, they will be on a switch. But do you you know what the color of the wires i will need to tap into, either the front or rear speakers? i dont wanna go guessing.
  #502
Old 04-04-2011, 07:52 PM
jake227's Avatar
Honestly don't know the color off the top of my head....When I installed mine I found a wiring diagram online and it was 100% correct. I think it was on here if you search or I might have found it by googling it, but I don't recall for sure.
  #503
Old 04-19-2011, 05:25 PM
JOHNNY CASH's Avatar
Great job on the write up!
I would like to install an amp and subs in my G for the longest. What's holding me back from doing this project, is that our G's trunk space is small and compact.
  #504
Old 04-19-2011, 07:38 PM
eurodre's Avatar
just did this install with a sundown sa12 and powered by an audipipe apsm1300
sounds GREAT, the bass is really centered on the inside of the car, no douchebass here
  #505
Old 05-14-2011, 09:55 AM
TbagzG35's Avatar
Wat silicone u use to cover hole mines leaks I did the same spot too on power through that plug also.
  #506
Old 05-15-2011, 08:03 PM
russofire's Avatar
I just installed the JL StealthBox and a JL500/1 amp ... Very happy plus I need the space for the golf clubs ...Next Dynamat ... Once I change brushes on driver window motor ...
  #507
Old 06-08-2011, 04:54 AM
SanityCore's Avatar
Quick questions for anyone that can answer it,
what are the details of the stock 2004 g35 coupe bose amp?
If I was going to get a 12 in my trunk what amp would I need to upgrade to.
Are there any 4080 enclosure boxes out there still?
Where else do people get there boxes?
  #508
Old 06-08-2011, 09:46 AM
eurodre's Avatar
got a question for you guys, what setting do you guys set the bass to on the stock headunit with the sub installed?
  #509
Old 06-08-2011, 10:14 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,037 Likes on 610 Posts
The Bose amp is a total POS that can't even power the stock components.
The amp you need depends entirely on what subwoofer you buy.
The "4080" enclosure is still available from the original designer at boxology: http://mysosinc.com/boxology_index.html
Others have been happy with the zenclosure-style box as well.
www.zenclosures.com
  #510
Old 06-09-2011, 03:45 AM
SanityCore's Avatar
Okay then if I got this sub-
http://cgi.ebay.com/JL-AUDIO-12W0V2-4-12-CAR-AUDIO-SINGLE-4-OHM-SUBWOOFER-/290572709467?pt=Car_Subwoofers_Enclosures&hash=item43a77bae5bor this one
http://cgi.ebay.com/ebaymotors/JL-AU...item43a71d1ec4
What amp would be good with it?
Would this one be fine?
http://cgi.ebay.com/ebaymotors/Jl-au...fAudioQ5fVideo
and then upgrade the BOSE amp to...
http://cgi.ebay.com/KICKER-DX200-4-4-CHANNEL-AMP-CAR-AUDIO-AMPLIFIER-200W-_W0QQcmdZViewItemQQhashZitem35b2a37d47QQitemZ230630325575QQptZCarQ5fAmplifiers
Would these be sufficient upgrades?
Headunit being this
http://www.sonicelectronix.com/item_...NA-W900BT.html
You have already rated this thread Rating: Thread Rating: 6 votes, 4.83 average.
Quick Reply: DIY: Add a sub to your Bose equipped G35 Coupe
