DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 6 votes, 4.83 average.
  #511
Old 06-09-2011, 11:37 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,038 Likes on 611 Posts
Originally Posted by SanityCore
Okay then if I got this sub-
http://cgi.ebay.com/JL-AUDIO-12W0V2-...item43a77bae5b
or this one
http://cgi.ebay.com/ebaymotors/JL-AU...item43a71d1ec4
What amp would be good with it?
Would this one be fine?
http://cgi.ebay.com/ebaymotors/Jl-au...fAudioQ5fVideo
and then upgrade the BOSE amp to...
http://cgi.ebay.com/KICKER-DX200-4-4...rQ5fAmplifiers
Would these be sufficient upgrades?
Headunit being this
http://www.sonicelectronix.com/item_...NA-W900BT.html
JL's definitely not the best price/performance sub out there. Your best bet is to PM eggyhustles or create a new thread with the type of music you want to listen to and your total budget, he's pretty good at catching such threads and replying. He doesn't frequent this board quite as often as me, but his experience with various subs and amplifiers dwarfs my own, so he's a lot better for recommendations on subs, amps & speakers.
Just by adding up the components you listed though, I'd recommend building a solid front soundstage instead of worrying about the subwoofer right now. Picking up a very solid 2-channel amp to power a pair of Boston Acoustics Pro60se's or Focal 165A1's will give you enough sound that you won't desperately need a subwoofer for a while, letting you save up for something good, instead of something cheap. It will also give you enough up front that the subwoofer you add won't overpower everything else and feel unbalanced.
If you're worried about running only two speakers, trust me - I ran my Pro60se's alone after my subwoofer's amp went out, and wasn't missing my subwoofer all that much, and probably could fool most people into thinking it was still hooked up and bumping.
  #512
Old 06-09-2011, 12:39 PM
SanityCore's Avatar
Well damn, you make those Pro60se's sound worth getting. You're saying I would no longer use the other stock speakers I have in the car, just these two? And these would need a 2 channel amp, even with my new h.u? What amp would be good with these ( replacing the stock bose?)
  #513
Old 06-09-2011, 01:05 PM
Yes, those two will sound better than the complete stock Bose system, hands-down.
Yes, you'll need the amp, these speakers sound better the more power they have, and headunits just don't push anywhere near enough to get the sound from them that they're capable of.
Just about any headunit will be fine, so long as you don't get some eBay discount chinese $99 unit.
  #514
Old 06-09-2011, 01:19 PM
SanityCore's Avatar
Alright thanks, and yeah. I'm getting this hu.
A little more expensive than $99.
  #515
Old 06-09-2011, 01:54 PM
I'd go with either of these over that one:
http://www.sonicelectronix.com/item_...IC-X930BT.html
http://www.sonicelectronix.com/item_...d-DNX6180.html
The Pioneer has 12 million POIs vs. 6 million on the Alpine and Kenwood.
The Kenwood has the best built-in navigation - Garmin.
My opinion is that the Pioneer has the best interface for everything but navigation.
  #516
Old 06-16-2011, 12:15 PM
qbanboy's Avatar
hey whats up guys i was reading this post and it really gave an idea of what i need to do....ill post some pics later on....
  #517
Old 07-03-2011, 07:22 PM
qbanboy's Avatar
I have some questions fro those who know!!! G35 coupe 2006
1) for the 6x9 speakers in the rear which wire is positive/negative?
I just install the 6x9 rear infinity kappa and planning to change everything else 2 component speaker front from kappa infinity and 2 middle rear (2 ways) from the same brand.
What amp do i need for all 6 speakers? watts and channels?
3) do i need to change my radio?
  #518
Old 07-03-2011, 07:48 PM
eurodre's Avatar
its in the 4th post of this thread...
"Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver "
  #519
Old 07-03-2011, 09:23 PM
Don't put rear speakers in, the 6x9's will do, and get a solid 4-channel amp to replace the Bose amp.
Since the Bose headunit (I assume you still are using) outputs a very low-voltage, differential-balanced audio signal, you'll need an amp that can take that input. There are a few brands that can do it, but the most common one that you can get your hands on is a JL amplifier.
For the Infinity speakers (not the greatest choice, BTW), you're probably fine going with the JL 300/4v2, but you can get a little more out of the speakers if you go with the JL XD400/4.
  #520
Old 07-04-2011, 11:47 AM
qbanboy's Avatar
I got future plans for the car like adding a sub and a double din from pioneer....now i dont understand why you said don't get the 2 mid rear speakers...i guess is because i will have to much mid and highs?
  #521
Old 07-04-2011, 11:58 AM
qbanboy's Avatar
i contact my local audio shop and he told me for this set up
2 component speakers front 61/2
2 2 way speakers middle rear
2 6x9 3 way speakers
1 10 inch sub JLAUDIO 10w6
Change head unit by a pioneer double din...
got with this amp!
JL Audio XD700/5 700W RMS, 5-Channel Class D XD Series Car Amplifier
  #522
Old 07-04-2011, 12:14 PM
It's not too much mids, it's just that if you have good speakers up front, particularly in the coupe, you don't need to waste money and watts on rear speakers.
If you're getting real subwoofers in the rear, I wouldn't bother replacing the 6x9s either, just get rid of them completely.
All you need in the coupe:
1 high-quality pair component 6.5 (Focal, BA Pro60se, or Image Dynamics)
1 10 or 12 inch sub (JL's good, but not the price is a bit much, look into sundown audio or Image Dynamics)
1 400+ watt 2 channel class a/b amp (soundstream reference are great sound quality and price, albeit larger than some)
1 500+ watt mono class D amp
^ The above will sound better and hit harder than what you listed, and probably cost less.
  #523
Old 07-04-2011, 12:31 PM
qbanboy's Avatar
well i already got the 6x9 so i will have to keep them..i guess i just get the two front components and the sub with the amp....
  #524
Old 07-04-2011, 12:54 PM
qbanboy's Avatar
bad news i dont have the same colors for the 6x9 brother!!!
Rear left 6x9
*blue - yellow stripes
*light green - green stripes
Rear right 6x9
*blue - red stripes
  #525
Old 07-04-2011, 01:46 PM
eurodre's Avatar
then you're not looking at the right wire pack, this one is right under the amp rack
You have already rated this thread Rating: Thread Rating: 6 votes, 4.83 average.
Quick Reply: DIY: Add a sub to your Bose equipped G35 Coupe
