Removal of 06AT shifter piece..
Old May 30, 2006 | 09:10 PM
cokecan's Avatar
Unhappy Removal of 06AT shifter piece..
So I screwed up.. I was following the 06mt DIY HU removal and got to the part where you need to take the piece off from over the shifter and ended up bending (almost breaking) the plastic that surrounds the shifter. So it now has a nice kink in the plastic.
I put the car in neutral, pulled down the boot, took the clip off, set the **** to the side, and then started pulling. Got half the the ring around the shifter off when it buckled.
Does anyone know the part number so I can replace it? And what is the correct way to get this part of the console off? Do you have to pull the little center part off first before you can pull the surrounding plastic off?
Any help would be appreciated..
Thanks!
-Brian
Old May 30, 2006 | 10:35 PM
bradakrez's Avatar
hmm...check out the DIY i made for ipod 05 AT with sat...see if it helps
https://g35driver.com/forums/audio-video-electronics/99632-pac-aai-nis2-ipod-adapter-installation-guide-05-dash-removal.html
i dont think you're suppose to just pull up from the top, you might have to go underneath....
Old May 30, 2006 | 11:42 PM
cokecan's Avatar
yep, should have pulled up the whole unit instead of just the inside plastic..
calling the dealer tomorrow to see if I can find the center part of the plastic..
Thanks!
-b
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
