to those who have aftermarket navi. vss wire?
Old Aug 9, 2006 | 06:20 PM
Igor911's Avatar
I thought the vss wire was wht/grn on the 4 wire harness behind the radio. I used that wire and my navi only reads up to 8 mph...even when I'm going 50. what wire did u all use
Old Aug 10, 2006 | 02:49 AM
vodkarocket's Avatar
Modded Member
HELP! I tapped that same wire in my 2005 sedan install, and my Avic reads 100MPH.
Anybody that knows the correct VSS wire for a 2005 sedan or coupe please post up!
Old Aug 10, 2006 | 04:28 AM
absolutg's Avatar
workin...
boris, ping bing... he's got all the wire mappings for our cars.
Old Aug 10, 2006 | 08:28 AM
Igor911's Avatar
I figured mine out last night. Turns out that the wire is correct. I just needed to let my navi re-learn the speed sensing. I put the unit in Tire Change mode, drove around for 15 mins and it works excellent now.
Old Aug 10, 2006 | 11:21 AM
Modded Member
^Not for me, I've been driving around like this for a month now, and my navi only partially works because I tapped the round speed sensor wire.
Old Sep 17, 2006 | 08:46 PM
QuadCam's Avatar
I tapped into the white/green wire behind the factory NAVI DVD-Rom player. I tapped into it so that I can use the navi search feautures while driving.
Do non-navi cars already have the wiring harness for the NAVI units?
Old Sep 18, 2006 | 12:03 AM
Igor911's Avatar
Yes because the Bose radio still needs the speed sensor wire for the volume adjustment based on speed...that's if that option is selected on the radio
Old Oct 19, 2006 | 05:29 PM
ttrank's Avatar
Grocery getter
Mine didn't have Bose or Nav and still had the VSS wire behind the stereo.
Old Oct 19, 2006 | 09:18 PM
khsonic03's Avatar
https://g35driver.com/forums/showthr...ht=avic+willow
Check out that post. It is at the bottom of the thread. Should be the same for you.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Fox843
Nov 7, 2015 05:43 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
BfloG35
Oct 16, 2015 05:22 PM
